No featrued products
Female USB-A 3.0 on PCB
This USB-A 3.0 PCB connector allows for easy mounting with solder pads that have a 2.54mm pitch (not an XH connector). In addition, each solder pad is silk-screened for easy wiring and soldering.
| Specifications | |
| Product type | Female USB-A 3.0 connector |
| Mounting type | To solder |
| PCB dimensions | 25 x 20mm |
| Mounting holes spacing | 20mm |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Female |
| Connector | USB-A |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
