TOPPING MINI300 Integrated Amplifier Silver
The Topping MINI300 is a Class D stereo amplifier delivering 2 × 125 W into 4 Ω in a fully symmetrical, high-efficiency design. Its 124 dB SNR, background noise below 15 µV and -106 dB crosstalk ensure faithful reproduction of the original sound. Housed in an aluminium chassis and equipped with a 12 V trigger, it combines performance, compactness and reliability, with built-in protection against overheating and overload.
4.5 / 5
Reference : 21261
138,66 €tax incl.
115,55 € tax excl.
Shipping date: 13-11-2026.
Topping MINI300 Balanced Integrated Amplifier Class D 2x125W 4 Ohm Silver
Topping MINI300 : Front view
The Topping Mini300 is a Class D stereo amplifier delivering 2x125 W into 4Ω in a fully balanced, high-efficiency design. Its 124dB SNR, background noise below 15µV and -106dB crosstalk ensure faithful reproduction of the original sound. Housed in an aluminium chassis and equipped with a 12V trigger, it combines performance, compactness and reliability, with built-in protection against overheating and overload.
Topping Mini300: A balanced Class D amplifier
The Topping Mini300 is a compact stereo amplifier delivering 2x125 W into 4Ω, designed to offer controlled power in a small format. Its Class D topology ensures high energy efficiency and excellent thermal stability, while the fully balanced design guarantees rigorous channel separation and reduced background noise.
The aluminium chassis enhances heat dissipation and protects the internal circuits from electromagnetic interference. A 12V trigger input also facilitates the integration of the Mini300 into an existing music system or home cinema.
Topping MINI300 : White, black and grey version
Topping Mini300: Outstanding audio performance
The architecture of the Mini300 is based on a selection of low-distortion components, optimised for transparency and precision. The amplifier has a signal-to-noise ratio of 124dB, background noise of less than 15µV and a harmonic distortion rate of < 0.0005%, ensuring faithful reproduction at any volume level.
Topping MINI300 : THD+N
The -106dB crosstalk ensures clear channel separation, preserving the stereo image and spatial coherence of the recording. This performance reflects an approach focused on neutrality and stability, without sound colouration.
Topping MINI300 : GX output and connector
Topping Mini300: Protection and reliability
Designed for long-term use, the Mini300 incorporates several protection circuits against overheating and overcurrent, ensuring stable operation over time, even during prolonged listening at high volumes.
Its combination of performance, compactness and quiet operation makes it an amplifier that is precise, efficient and easy to integrate into a modern hi-fi system.
Topping Mini 300 test by Audio Science Review
"The Topping Mini 300 offers meticulous workmanship with excellent implementation of Class D chip-based amplification. For an affordable price, you get a stereo amplifier that produces a lot of power while taking up very little space. It certainly breaks the cliché that you have to spend a lot of money to get good performance. I highly recommend the Topping Mini 300 stereo amplifier."
Technical specifications
Product typeAmplificateur intégré
Inputs1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm
OutputSpeaker terminal
Output power2x140W @ 4Ω THD+N<10%
2x125W @ 4Ω THD+N<1%
2x85W @ 8Ω THD+N<10%
2x65W @ 8Ω THD+N<1%
Load impedance4-8Ω
12V trigger
Single-ended input specifications
Total harmonic distortion more noise (THD+N)< 0.0006% @ 4Ω 5W
< 0.0008% @ 8Ω 5W
Signal-to-noise ratio (SNR)121dB
Dynamic range121dB
Frequency response20Hz-40kHz (±0.3dB)
Output level65Vpp @ 4Ω
68Vpp @ 8Ω
Noise< 15uVrms
Crosstalk-90dB
Input sensitivity1.3Vrms
Gain25dB
Channel balance0.1dB
Balanced input specifications
Total harmonic distortion more noise (THD+N)< 0.0005% @ 4Ω 5W
< 0.0004% @ 8Ω 5W
Signal-to-noise ratio (SNR)124dB
Dynamic range124dB
68Vpp @ 8Ω
Noise< 15uVrms
Crosstalk-106dB
Input sensitivity2.6Vrms
Gain19.2dB
Power supply voltage38V DC
ColorSilver
Package1x Topping Mini300
1x 38V mains adapter (2-pin GX connector)
Topping MINI300 : Measures
InputJack 6.35mm
ColorSilver
Channel2 (Stereo)
Amplifier chipN/A
Power (W)125.0
2 reviews
Toppping Mini300 ... entre 3 et 4 étoiles suivant l'usage
Je ne suis pas totalement convaincu. A ce prix, la qualité est imbattable, mais il y a clairement un soucis de puissance et de maitrise pour mes enceintes colonnes. J'estime que la puissance utilisable est de l'ordre de 2x15W max pour celles-ci. Au delà, la qualité s'en ressent. Je pense que l'ampli est plus à l'aise avec des bibliothèques. Les basses sont tendues et propres (même en poussant un peu). Elles ne sont toutefois pas très profondes. Les mediums me semblent un peu ternes, légèrement en retrait. Les aigus (et medium hauts) sont précis, clairs et détaillés. La scène est bien déployée. Sur le premier tier du volume, c'est très bon (60db / 70db max). Au delà, en poussant, les basses restent tendues, mais les mediums semblent se faire manger par les aiguës qui deviennent fatiguant et agressifs. Conclusion : le son est neutre et vraiment incroyable pour ce prix sur la plage utilisable (= premier tier). Mais c'est un peu chiche quand on aime pousser un peu (dépendant également des enceintes). J'allais oublier ! Le boitier est de bonne facture, ça ne fait pas du tout camelote. ATTENTION ! Le borniers sont tout petits. Prévoyez des fiches bananes ou des câbles de section inférieur à 4mm2 (12 AWG).
This review has been posted for TOPPING MINI300 Balanced Integrated Amplifier Class D 2x125W 4 Ohm Silver
topping au top
Tout petit ampli en alu bien fini, silencieux, dynamique et il tient bien les basses qui ne bavent pas.
La puissance de 2*50W sous 8 Ohms sans distortion est bien là, très suffisante pour mes enceintes colonne.
Très content de cet achat
The Topping MINI300 is a Class D stereo amplifier delivering 2 × 125 W into 4 Ω in a fully symmetrical, high-efficiency design....
