FURUTECH FI-UK NCF (R) Power Connector UK Type G Copper Rhodium Plated NCF Alpha Treated 250VAC 13A Ø20mm
The Furutech FI-UK NCF (R) is a UK power connector with an excellent design quality. Its contacts are made of Rhodium plated copper, ensuring both excellent conductivity and resistance to oxidation and corrosion.
By buying this product you get 36 loyalty points
Reference : 15724
181,00 €tax incl.
150,83 € tax excl.
Shipping date: 06-10-2026.
Main Connector UK 250VAC 13A NCF Alpha Treated Rhodium Plated Copper Ø20mm
Furutech FI-UK NCF (R) Connecteur Secteur UK 250VAC 13A NCF Cuivre Plaqué Rhodium Traité Alpha Ø20mm
The Furutech FI-UK NCF (R) is a UK power connector with an excellent design quality. Its contacts are made of Rhodium plated copper, ensuring both excellent conductivity and resistance to oxidation and corrosion. The body of this connector uses the proprietary NCF (Nano Crystal Formula²) damping technology, using a crystalline material with two active properties. First, it generates negative ions to eliminate static charges. Second, it converts thermal energy into far infrared. Furutech combines this material with ceramic nanoparticles and carbon powder for their piezoelectric damping effects.
Each contact also benefits from the brand's α (Alpha) treatment, a cryogenic and demagnetization process to promote stable and optimized transmission.
Product typeUK Main connector
Contacts materialCopper
Contacts platingRhodium
Contacts treatmentα (Alpha)
Body materialPolycarbonate NCF
ABS
Accepted cable diametersØ6-20mm
Max voltage / current250VAC 13A
Mounting typeTo solder
Dimensions48 x 50.2 x 55.8mm
Max cable diameter (mm)20.0
Mounting typeN/A
ConnecticMale
ConnectorType G (BS 1363 - IS 401)
Rated current (A)13.0
The Furutech FI-UK NCF (R) is a UK power connector with an excellent design quality. Its contacts are made of Rhodium plated copper, ensuring both...
