Pins connector for Headphones HD800 / HD800S / HD820 / D1000 Gold Plated Ø4mm Black (Pair)
This pair of connectors is designed around the brand's know-how. With two pins, they are suitable for the design of cables compatible with some Sennheiser headphones, such as the HD800, HD800S, HD820 as well as the ENIGMAscoutics Dharma D1000 headphones. The design of these connectors guarantees a flawless sound quality.
4.7 / 5
Reference : 17496
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 18-07-2025.
Pins connectors for headphones
HD800 / HD800S / HD820 / D1000 Gold plated Ø4mm Black (Pair)
Connecteur pour Casques HD800 / HD800S / HD820 / D1000 Plaqué Or Ø4mm Noir (La paire)
High performance headphone connectors with modern design
These headphone connectors allow retransmission of the sound signal without loss thanks to their design in pure copper, moreover the gold plating of the connectors allows them to resist oxidation and corrosion. On the design side, we will note the plug that is easy to disassemble and connect. In addition, the connectors have a red and blue marking to differentiate them and can accommodate a cable up to 4mm diameter.
SpEcifications
Product type2 pins connector for Sennheiser headphones and ENIGMAscoutics Dharma D1000
Contacts materialCopper
Contacts platingGold
Body materialMetallic Shell
Cable clamp materialCopper
Max cable diameterØ4mm
Total length32mm
CompatibilityHD800
HD
800S
HD820
D1000
Connection typeTo solder
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
Contacts number2
ConnectorN/A
3 reviews
Belle qualité
Prise de qualité, se connecte parfaitement et de manière aisée, même mieux que l'originale.
Contrairement à ce que j'ai pu lire dans les commentaires, les prises sont identifiées avec un point rouge, et l'autre bleu pour différencier Droite/Gauche.
Idem à l'intérieur, un petit point rouge est présent un des pins.
Les connecteur sont très fins (mais valable pour toutes les prises), faut pas trembler et avoir de bons yeux pour effectuer la soudure !
Je recommande vivement, rapport qualité prix excellent.
This review has been posted for Pins connector for Headphones HD800 / HD800S / HD820 / D1000 Gold Plated Ø4mm Black (Pair)
Decent connectors for headphones
These connectors have pretty decent build quality and are nicely slim for the purpose. However these lack practical means for cable strain relief thus only 4 stars. There could be also some printed labels for left and right channels. Works well for the price.
As good as original connectors
To me it even seems better than original, fits perfectly.
This pair of connectors is designed around the brand's know-how. With two pins, they are suitable for the design of cables compatible...
