FOSI AUDIO BOX X3 MM Phono Preamplifier with Tubes 2xGE5654 Stereo Bluetooth 5.0 Black
With its BOX X3 tube preamplifier, big brother to the BOX X2, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube amplification.
4.8 / 5
Reference : 18083
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 20-05-2025.
FOSI AUDIO BOX X3
FOSI AUDIO BOX X3 Préamplificateur Phono MM à Tubes GE5654 Stéréo Bluetooth 5.0 Noir
With its BOX X3 tube preamplifier, big brother to the BOX X2, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube amplification. A blend of vintage and modern technology, the BOX X3 also features Bluetooth 5.0 functionality for wireless audio sources.
On the front, the BOX X3 features a volume control with bass and treble adjustment, plus a 3.5mm jack auxiliary input for connecting various audio sources such as a telephone, DAC, or others. The rear panel features a stereo RCA input and output with a GND terminal for phono coupling with a turntable (MM).
The FOSI Audio BOX X3 is the ideal companion for a power amplifier or a pair of active speakers. It will boost the sound quality of your hi-fi system. Supplied with a pair of GE5654 tubes (7-pin), these can be easily replaced by 5654W / 6K4 / 6J1 / 6J1P / 6J2 / 6J3 / 6J4 / 6J5 / 6AK5 / 6K4 / 6ZH1P / 4.3a / 4.3B / EF95 tubes, if you prefer a different sound. Overall, the BOX X3 is an excellent entry-level preamplifier.
Product typeMM phono preamplifier with tubes
Tubes2x GE5654
Inputs1x Stereo RCA input with GND
1x Auxiliary input 3.5mm jack
Bluetooth
Output1x RCA stereo
Output voltage level650Mv @3mV 1kHz
SNR≥ 98dB
THD≤ 0.1%
Frequency responseStandard RIAA
Volume control
Compatible cell typeMM
GND terminal
Power supplyDC 12V 1.5A
Dimensions101 x 120 x 35mm
Weight350g
Package1x MM tube phono preamplifier Fosi Audio BOX X3
2x GE5654 7-pin tubes
1x Mains adapter
1x Bluetooth antenna
InputJack 3.5mm
ClassTube amp
4 reviews
Préamplification et réception bluetooth au top !
Acheté pour dynamiser un ampli vintage dont la partie préamplification phono n'était pas au top, je suis enthousiasmé du rendu ! Une très belle dynamique, l'évolution est flagrante ! Mon système audio a complètement changé avec ce petit boitier.
Petit bémol, le son parait tellement qualitatif que le rendu en est presque digital. Je vais tester d'autres lampes dans l'avenir pour trouver une texture de son plus chaleureuse.
Autre bonne surprise, la partie réception bluetooth est de haute volée ! Réactive à la connexion, le gain d'amplification est supérieur à d'autres boitiers essayés avec une amélioration de la dynamique.
Un de mes meilleurs achats audio
This review has been posted for FOSI AUDIO BOX X3 MM Phono Preamplifier with Tubes 2xGE5654 Stereo Bluetooth 5.0 Black
trés bon matériel
Très bon petit préampli phono - Sonne nettement mieux que celui de l'ampli AKAI - Les fonctions Bluetooth et line son des ajouts très intéressants - Les tubes fournis sont très corrects mais le remplacement par des SOVTEK change complétement la donne. Le son est extrêmement clair et précis, notamment en utilisant les réglages grave et aigus afin d'adapter à son gout ou au rendu de ses enceintes.
Expérience Fosi Audio
J'ai attendu après un peu plus de 2 mois d'utilisation pour donner mon avis.
Je l'utilise pour amplifier le son de ma platine Denon DP300F vers mon ampli Bose 321, car le préampli intégré n'est pas assez puissant.
Point Forts (+)
- Le design est assez sympa et l'objet est plutôt discret
- La possibilité de connecter un port Bluetooth a simplifié mon système son. C'est ce qui m'a orienté vers ce produit et il marche très bien (utilisé en soirée pendant 5h, pas de déconnexion intempestives)
- La qualité du préampli est là. Le son est plus propre, mieux augmenté et c'est pratique d'avoir un réglage du volume possible
Point faible:
- J'ai failli renvoyer le produit car j'ai galéré à insérer une des deux lampes. Autant l'une se mettait simplement, autant l'autre, j'ai du revoir tous les espacements entre les pattes. Je suppose qu'il s'agissait d'une lampe reconditionnée, et c'est ce qui justifie que je ne mette pas 5 étoiles.
En conclusion: que vous ayez besoin d'améliorer l'amplification d'une platine externe ou que vous vouliez juste apporter un connecteur Bluetooth, ce Fosi Audio répond bien aux besoins.
Peut-être que des mélomanes avertis lui trouveront des limites, mais à mon niveau, c'est plus que correct, vu le prix
Chouette préampli bon marché.
Acheté il y a 3 jours, livré ce matin, je suis très satisfait du son délivré (le velouté précis des lampes).
Initialement prévu pour une Elipson Chroma 400 Riaa BT, le BOX 3 ne fonctionne pas convenablement (distortion) car il y a un préampli déjà intégré à la platine :(
Par contre, une fois migré sur une Technics SL 1900 il fait parfaitement le job (son chaud et doux bien défini qui garde sa dynamique).
Parfait, sans se ruiner !
With its BOX X3 tube preamplifier, big brother to the BOX X2, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing...
