DAYTON AUDIO TT-1BT Vinyl Turntable Wood
Dayton Audio unveils its TT-1BT turntable, a blend of vintage and modernism. This belt-driven turntable features Bluetooth and a USB port for extended connectivity. It's also equipped with an Audio-technica AT-VM95E pickup, for exceptional playback quality and clear, detailed sound reproduction.
By buying this product you get 36 loyalty points
Reference : 19281
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 07-04-2026.
Grantie 5 ans
DAYTON AUDIO TT-1BT Vinyl Turntable USB Bluetooth Audio-Technica AT-VM95E Wood
Photo of DAYTON AUDIO TT-1BTW vinyl turntable
Dayton Audio unveils its TT-1BTW vinyl turntable, a blend of vintage and modernism. This belt-driven turntable features Bluetooth and a USB port for extended connectivity. It's also equipped with an Audio-Technica AT-VM95E cartridge, for exceptional playback quality and clear, detailed sound reproduction. This turntable is sure to delight you, whether you're already a vinyl enthusiast or a beginner to 33 and 45 rpm records. Here are the highlights of the Dayton Audio TT-1BTW turntable:
  • Interchangeable Audio-Technica AT-VM95E cartridge (MM cell) with elliptical stylus tip for superior audio quality.
  • Precise traction control and counterbalance.
  • Bluetooth functionality for easy pairing with wireless speakers or headphones.
  • USB port for MP3 encoding of your favorite vinyl and enjoyment on your computer, tablet or smartphone.
  • A one-piece straight tone arm made of aircraft-grade aluminum.
DAYTON AUDIO TT-1BTW: Audio-Technica AT-VM95E cartridge
Dayton Audio has chosen to install a high-quality Audio-Technica AT-VM95E MM cartridge. This cartridge attenuates unwanted resonances and provides reliable playback for transparent sound, a wide soundstage and immersive bass. This cartridge is easily replaceable for upgrading or replacement.
Photo of Audio-Technica AT-VM95E cartridge
Photo of DAYTON AUDIO TT-1BTW turntable belt
DAYTON AUDIO TT-1BTW: an innovative belt drive system
The belt drive system of the Dayton Audio TT-1BTW vinyl turntable is accompanied by an electronic sensor that constantly adjusts playback speed to avoid any fluctuation. In addition, the drive mechanism eliminates potential vibrations caused by the motor. These factors greatly enhance playback precision, and bring out the textures and different tonalities that make any vinyl record so rich.
DAYTON AUDIO TT-1BTW: High-quality aluminum tone arm and platter
The straight tone arm is made from a single piece of aluminum for maximum rigidity. This low-resonance tone arm, combined with a high-end platter, minimizes wobble and accurately tracks all playback speeds. A control knob instantly adjusts the playback speed from 33T to 45T, while a second knob manages the motor's stop/start function.
Photo of DAYTON AUDIO TT-1BTW turntable tonearm and platter
DAYTON AUDIO TT-1BTW: extensive connectivity
The TT-1BTW features high-quality RCA connectors with a Phono/line selector for easy integration into any audio system. In addition, Bluetooth functionality lets you broadcast the warm sound of your vinyl to any Bluetooth receiver, whether speakers or wireless headphones.  Moreover, a USB-B port lets you encode your vinyl in MP3 so you can enjoy it on a variety of devices such as your computer, tablet or smartphone.
Photo of DAYTON AUDIO TT-1BTW turntable connectors
Product typeVinyl tunrtable
Driver typeBelt drive
Playback speeds33T 45T
Playback speed variation±1.0%
Wow et flutter≤ 0.15%
SNR55dB
Tonearm
Type of tonearmStraight with static balance
Toenarm materialAluminum
Effective length218.5mm
Overhang18.5mm
Headshell terminalØ1.2mm 4 pins
Cell typeMM cell
Output voltage4mV(@1 kHz, 5 cm/sec.)
Channel balance< 2.0dB
Channel separation> 20dB
Recommanded impedance load resistance47kΩ
Mass6.1g (0.22 oz)
Recommanded vertical tracking force1.8-2.2 g (2.0g standard)
Digital outputs
Bluetooth version5.0
Supported Bluetooth codecsQualcomm aptX
USB output sample rates44.1kHz / 48kHz
Power consumption6W
Power supply12V DC 500mA
Total dimensions415 x 340 x 148mm
Weight6.2kg
ColorWood
Package1x DAYTON AUDIO TT-1BTW turntable with Audio-Technica AT-VM95E cartridge
1x Dust Cover
1x Platter With Belt
1x Reversable Slipmat
1x Counterweight
1x Anti-skate Weight
1x 45 RPM Adaptor
1x Cartridge Alignment Protractor
2x Lid Spare Rubber
1x USB-B to USB-A cable
1x RCA cable with ground wire
1x 12V power adapter
ColorWood
Cartridge typeMM (Moving Magnet)
Rotation speed33 RPM
Rotation speed45 RPM
Dayton Audio unveils its TT-1BT turntable, a blend of vintage and modernism. This belt-driven turntable features Bluetooth and a USB port for...
