No featrued products
Ultra Low Noise Voltage Regulator +12V
The high quality LDOVR LT3045-LT78XXG regulator ensures a very low noise level (0.8%Vrms) and a very low pressure drop (low-dropout). This model is compatible with LM78xx regulators (LM7805, LM7812, etc.) and is therefore an ideal replacement solution.
| Specifications | |
| Product type | Linear voltage regulator |
| Output voltage | +12V |
| Output current | 500mA |
| Input voltage | 1.8V to 20V |
| Dropout voltage | 260mV |
| RMS Noise | 0.8µVRMS (10Hz-100kHz) |
| Spot noise | 2nV/√Hz @ 10kHz |
| PSRR | 76dB @ 1MHz |
| Protections | Fixed current limit Thermal protection |
| Operating temperature range | -40°C / +125°C |
| General | |
| PCB Dimensions | 25.4 x 15mm |
