Ultra Low Noise Linear Voltage Regulator -3V / -18.5V 1A
The high quality LDOVR TPS7A3301-79XXG regulator provides very low noise (16µVrms) and low-dropout. This model is compatible with both LM79xx and LM337 regulators and is therefore an ideal replacement solution.
| Specifications | |
| Product type | Linear voltage regulator |
| Output voltage | -3V à -18.5V |
| Output current | 1A |
| Input ovltage | -3.5V à -25V |
| Dropout voltage | 307mV @ 1A |
| Output voltage noise | 16µVrms (10Hz, 100kHz) |
| Ripple rejection | 72dB (10kHz) ≥55dB (10Hz, 10MHz) |
| Protections | Fixed current limit Thermal protection |
| Operating voltage temperature | -40°C / +125°C |
| General | |
| PCB Dimensions | 25.4 x 15mm |
| Output voltage (V) | -3.0 |
| Output voltage (V) | -18.5 |
| Output current (A) | 1.0 |
| Input voltage (V) | -3.5 |
| Input voltage (V) | -25.0 |
