WiFi 2.4G DLNA AirPlay Bluetooth 4.0 16bit 44.1kHz
This small, compact and practical WiFi and Bluetooth receiver will allow you to transform a classic audio system into a real network player. It will allow you to easily stream your music from devices connected to your local network, while enjoying remote control thanks to the free ALink mobile application. The latter also offers access to streaming services such as TIDAL or Spotify, as well as to numerous web radio stations via TuneIn and iHeartRadio. It will also allow you, in association with several WiFi receivers, to create a real multi-room ecosystem to equip all your rooms. The Bluetooth reception will allow you to broadcast your music as easily as possible, directly from a smartphone or tablet. On the connectivity side, you'll find RJ45 and 3.5mm jack as inputs and Toslink optical and 3.5mm jack as outputs.
| Specifications | |
| Product type | WiFi / Bluetooth receiver |
| Inputs | WiFi Bluetooth 4.0 1x Ethernet RJ45 10/100M 1x Jack 3.5mm |
| Outputs | WiFi 1x Optical Toslink 1x Jack 3.5mm |
| WiFi frequency band | 2.4G |
| WiFi Protocol | 802.11 a/b/g/n |
| Supported Bluetooth protocols | A2DP, AVRCP, PBAP |
| Supported sampling rates | PCM up to 44.1kHz |
| SNR | Analog output : > 80dB Optical output : > 100dB |
| THD | Analog output : < 1% Optical output : < 0.01% |
| Frequency response | 20Hz - 20kHz |
| General | |
| Supply voltage | 5VDC >500mA |
| Dimensions | 140 x 86.5 x 25mm |
| Weight | 165g |
| Color | Black |
| Package | 1x WiFi/Bluetooth receiver 1x USB-A to Micro USB power cable 1x RCA to Jack 3.5mm cable 1x Jack 3.5mm cable |
| Input | Jack 3.5mm |
| Input | RJ45 |
| Input | Bluetooth |
| Input | WiFi |
| Output | Jack 3.5mm |
| Output | Optical Toslink |
| Output | WiFi |
| DAC / ADC Chip | NC |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
| Transmission / Reception protocol | DLNA |
| Transmission / Reception protocol | WiFi |
| Supported Bluetooth codecs | N/A |
