NEUTRIK NC5FXX-B Gold Plated 5 Way Female XLR Connector Ø8mm (Unit)
5-pole XLR female connector with metal housing and gold-plated contacts. Simple handling and assembly with only four parts and the same number of threads.
Reference : 14482
10,60 €tax incl.
8,83 € tax excl.
Shipping date: 07-04-2026.
Neutrik NC5FXX-B
XLR 5 pole female connector with metal enclosure and gold-plated contacts.
Easy to handle with only four different parts to assemble and disassemble.
The contact block is removable and allows a comfortable cable installation. Built in hard plastic (polyamide), it can be removed by pulling the rear of the connector.
The female contacts have a unique cage design, with seven independent contact springs for low contact resistance and high intergrity. A cleverly positioned barrier prevents welding from overflowing to another contact.
Allowed Cable Diameter3.5 to 8.0 ⌀mm
Contactsgold plated
BodyBlack
Insulation materialPE
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticFemale
Contacts number5
ConnectorXLR
5-pole XLR female connector with metal housing and gold-plated contacts. Simple handling and assembly with only four parts and the same number of...
