AUNE B1 Portable Headphone Amplifier Class-A discrete output
Reference : 9470
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The famous brand Aune presents here its new Headphone Amplifier.
This version has been revised to better adapt to low impedance headphones and intras.
It is equipped with a Class-A discrete high-performance circuit delivering up to 100mW under 300 Ohm.
It is equipped with high quality components such as Vishay SM resistors and Murata capacitors.
The basses are clear and the top of the spectrum very well balanced. He transcribes a rich and detailed sound.
Its surprising design lets you see the architecture of the amplifier through its windows.
Characteristics :
  • Chassis Brushed aluminum anodized black
  • Supported Impedances: 16 - 300 Ohm
  • Output power (Class A) under: 300 Ohm = 100mW, 32 Ohm = 50mW, 16 Ohm = 25mW
  • THD + N: 0.0008% at 1kHz / 50 Ohm
  • Frequency response: 20Hz - 20kHz
  • SNR> 124dBA @ 600RZ
  • Line In Jack 3.5mm
  • Headphone Jack Jack 3.5mm
  • Volume control via potentiometer
  • Gain control
  • Current control (20 or 40mA)
  • Dimensions: 65x110x18mm
  • Weight: 230g
  • USB cable type-A to micro USB and cable 3.5mm jack to 3.5mm jack 10cm supplied
: //audiophonics.fr/img/cms/Qobuzissime-300x121.jpg "alt =" Qobuzissime "width =" 300 "height =" 121 "/>
Test in English (Click here)
Aune B1
Aune B1
Aune B1
Aune B1
ClassClass A / AB
2 reviews
Un ampli magnifique et aux qualités sonores remarquables
Cet ampli a été très bien conçu et donnera du pep's à toutes vos sources moyennes!
sur des fichiers HD il apporte également un plus qualité , précisions , donne de la texture aux voix et instruments.
Sa signature est assez neutre et conviendra à grand nombre d'auditeurs, je l 'ai testé sur un DAP FIIO X3 et casque ATH MSR7 , low gain cela suffit avec le X3 SUR la position faible voltage , les voix sont mises en valeur, sur le high voltage on note une amélioration de la scène sonore et la séparation des instruments, ce paramètre permet de clarifier la musique , très sympa sur des écoutes chargées , complexes!
pour le HIGH GAIN uniquement testé avec iphone 6 qui le demandait vraiment ! et là il donne vraiment du dynamisme à cette source de moyenne qualité ( iphone6 + qobuz qualité CD)
Pour la finition produit je dirais SUPERBE , boitier ALU (un peu lourd d'ailleurs cela ne donnera pas trop envie de l'utiliser en nomade) et conception ORIGINALE avec l'électronique apparente)
Le seul bémol est le manque d'une sortie casque 6.35mm puisque cet ampli sera utilisé en sédentaire et peut alimenterdes casques plus gourmands.
Notons également une autonomie moyennes (3/4h max en hvoltage)
This review has been posted for AUNE B1 Portable Headphone Amplifier Class-A discrete output
Le seul bémol est le manque d'une sortie casque 6.35mm puisque cet ampli sera utilisé en sédentaire et alimente des casques plus gourmands
