SONIC IMAGERY LABS 994ENH-TICHA Dual High Performance Discrete OPA DIP8
Sonic Imagery Labs' model 994ENH-TICHA is a high-performance dual discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. The 994ENH-TICHA discrete OPA achieves a new standard of noise excellence with a measurement at 0.89nV/Rt.Hz (@ 1kHz).
Reference : 9354
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 14-07-2026.
Sonic Imagery Labs 994ENH-TICHA Dual High Performance Discrete OPA DIP8
Sonic Imagery Labs 994ENH-TICHA OPA
Sonic Imagery Labs' model 994ENH-TICHA is a high-performance dual discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. The 994ENH-TICHA discrete OPA achieves a new standard of noise excellence with a measurement at 0.89nV/Rt.Hz (@ 1kHz). This very low noise is combined with excellent high-speed specifications, extremely low output distortion and precision parameters (offset voltage greater than 200µV, open-loop voltage gain of 118dB). Although the 994ENH-TICHA input stage operates at close to 1mA to ensure low voltage noise, the input bias current remains below 1µA.
The SMT design is entirely discrete, but has been completely redesigned to use a pair of highly accurate matched differential transistors to meet the requirements of ultra-low noise and THD audio systems. In addition to the improved input stage, the 9904NH-TICHA uses high-precision, temperature-stable power supply-independent current sources. Supply-independent current sources ensure that the bias remains locked at the optimum operating point, whatever the supply voltage and temperature. The low-distortion Class A output stage can absorb or supply 150mA, enabling this module to drive transformers with ease.
Sonic Imagery Labs 994ENH-TICHA: Wiring diagrams and dimensions
Product typeOPA
THD+N0.0003% @ 1kHz
Noise0.89nV/rtHz typ.
Output current150mA @ 75
Output level+26dBu @ 600Ω
Supply voltage range±7.5V to ±24V
Input offset voltage (Vos) @ Rs=0Ω, Av=unitaryTyp : 0.22mV
Max : 0.45mV
Input offset current (Ios)Typ : 4nA
Max : 100nA
Input bias current (Ib)Min : 0.8uA
Typ : 1uA
Max : 1.2uA
Voltage gain (open loop) (Avol) @ -3dB, 43HzMin : 115dB
Typ : 118dB
Max : 120dB
Output voltage swing (Vom) @ Vs=±24V, Rl=600Ω, Av=10Min : 41Vpp
Typ : 42Vpp
Output voltage swing (Vom) @ Vs=±24V, Rl=75Ω, Av=10Min : 38Vpp
Typ : 38.5Vpp
Input common mode range (Vcm) @ Rl=600ΩMin : ±12V
Typ : ±12.5V
Common mode rejection ratio (CMRR)Min : 100dB
Typ : 100dB
Power supply rejection ratio (PSRR)Min : 100dB
Typ : 110dB
Supply current (Iq) @ Vo=0, gnd inputs, Vcc=24VMin : 32mA
Typ : 34mA
Max : 38mA
Supply current (Iq) @ Vo=0, gnd inputs, Vee=24VMin : 30mA
Typ : 32mA
Max : 34mA
Slew rate (SR) @ Rl=600ΩMin : 17V/uS
Typ : 18V/uS
Max : 19V/uS
Slew rate (SR) @ Rl=75ΩMin : 15V/uS
Typ : 16V/uS
Max : 17V/uS
OPA TypeDual
Sonic Imagery Labs' model 994ENH-TICHA is a high-performance dual discrete operational amplifier (OPA) designed for professional audio...
