AUDIOPHONICS Filter Wire Sector SCHAFFNER FN9222B CS-321B 3A
Audiophonics Filtre Secteur sur fil SCHAFFNER FN9222B CS-321B
Reference : 6253
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
This mains filter is composed of a SCHAFFNER FN9222B, an Elecaudio CS-321B cable and an IEC connector. <sp"font-style: normal; font-size: normal;"This accessory allows you to clear the power supply of your device from EMI interference and to have a clean voltage
  • SCHAFFNER FN9222B IEC Anti-Parasites / EMI 230V Sector Filter
The reference for high performance mains filter: the model FN9222BManufacturerSchaffnerand designed to filter disturbances when the capacitors prove insufficient. <sp"font-style: normal; font-size: normal;"Dramatic effectiveness against electromagnetic interference (EMI) propagated by radiation or conduction./ Span>
Product in accordance with IEC 950 standard, approved UL, CSA, TÜV, SEMKO, NEMKO and FIMKO, and meeting the requirements of Overvoltage category II (IEC664) .
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_1.jpg
Specifications:
  • Operating Voltage: 250V Max 50 / 60Hz
  • 3A
  • Leakage Current: 2μA
  • Operating Frequency: Up to 400Hz
  • Capacity: 0.1μF x2
  • Self: 12.0 mH x 2
  • Resistance: 1MΩ
  • Operating Temperature Range: -25 ° C to + 85 ° C
  • Certifications: UL, CSA, TÜV, SEMKO, NEMKO & FIMKO
  • Weight: 40g
  • Recessed dimensions: 28x20.5mm
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_3.jpg
A: 48mm
B: 22.5mm
C: 40mm
D: 38.4mm
F:
5.5mmH:3.3mmJ:13.3mmS:90 °
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_2.jpg
  • ELECAUDIO CS-321B OCC - Mains cable OCC Teflon insulation 3x2.50mm²
Power cable with very thin insulated FEP strands for more details and good flexibility.
Features:/ Strong>
  • Phase and Neutral Conductors: 1x26x0.12mm OCC + 6x38x0.10 OFC = 2.5mm²
  • Earth conductor: 1x26x0.12mm OFC + 6x38x0.10 OFC = 2.5mm²
  • Isolateion Teflon conductors (FEP)
  • Cotton padding
  • Mylar Shielding
  • Shielding Drain: 26x0.16mm
  • OFC shielding braid
  • PVC Insulation
  • External Diameter: 10mm
  • Bending radius: ~ 8cm
https://www.audiophonics.fr/images2/6253/6253_FILTRESURFIL_1.jpg
Length 30 cm
https://www.audiophonics.fr/images2/6253/6253_FILTRESURFIL_2.jpg
Length 30 cm
