AUDIOPHONICS Dual linear Power supply USB 2x 5V 1.5A 7.5W LT1086
Dual linear Power supply USB 2x 5V 30W LT1086
Reference : 9947
99,00 €tax incl.
82,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
dual-linear-power-supply-usb-2x-5v-30w-l
Dual linear regulated power supply USB 2x5V
This linear regulated power supply is designed to deliver stable power to any of your amplifiers, DAC, etc ... It works with two separate toroidal transformers and is ideal to minimize as much as possible distortions and power-related noises in your sensitive devices.
Coming in a 100% aluminum casing, this power supply is protected parasites occuring from other nearby electrical devices.
A digital display shows in real time the voltage supplied, it allows the user to confirm in just a glimpse that no anomally are present.
Output is two USB ports and two Locking output type Aviation-type.
With its low price, this power supply is one of the best value for money on the market.
Typelinear regulated power supply
HousingAluminum
RegulatorLinear Technology LT1086 IC
Input VoltageAC 220-240V
Voltage / output current2x 5V 1.5A DC
Outputs2x USB-A
2x Micro Aviation (red = positive / black = negative)
Power2x 7.5W
Digital displayx2
Dimensions145 x 135 x 60 mm
Weight1.4kg
Package Contents
GX cable 16 to DC jack 5.5 / 2.1mmx2
USB 2X5V regulated 1.5A powerx1
InputIEC C14
OutputGX12
Output voltage (V)5.0
Output current (A)1.5
Input voltage (V)230.0
Power SupplyLinear
3 reviews
Pratique
Cette alimentation me permet d'alimenter une chromcast, une chromcast audio et un switch. Le tout pouvant être coupé d'un seul coup plutôt que de rester alimenté en permanence. Elle est assez stable entre 5V et 5.2V. Parfait
This review has been posted for AUDIOPHONICS Dual linear Power supply USB 2x 5V 1.5A 7.5W LT1086
Inutilement essentiel 2 - suite et fin
car cela apporté à la chromecast doublé du DAC beaucoup plus de tenue dans tous les registres.
En outre, c'est plutôt solidement construit. C'est pas en plastoc.
Concernant la fiabilité, il faut voir sur le long terme.
Mais de prime abord, moi, je suis fan...
De prime abord, une alimentation supplémentaire en remplacement de celle d'origine peut paraitre totalement inutile (c'était mon humble opinion).
Cependant, dans le cadre d'une google chrome-cast audio accompagné d'un petit dac smsl sankrit 10, je me suis dit, je vais alimenter tout ça avec une seule alim que je pourrais éteindre en une seule fois.
Et bien alors, bien m'en a pris c
