IFI AUDIO GO BLU AIR Portable DAC Headphone Amplifier Bluetooth
The iFi Audio GO Blu Air is a portable Bluetooth DAC and headphone amplifier designed to follow you everywhere. Both practical and high-performance, it features a magnetic clip for easy transport on the go. Powered by its Qualcomm QCC5144 chip dedicated to Bluetooth 5.2, the Go Blu Air offers high-performance audio reception, thanks in particular to its support for a variety of codecs (LDAC, LHDC, aptX, etc.), as well as its Circus Logic CS43131 DAC chip.
4.0 / 5
Reference : 21660
119,00 €tax incl.
99,17 € tax excl.
iFi Audio Go Blu AirPortable DAC Headphone Amplifier CS43131 Bluetooth 5.2 aptX Adaptive LDAC LHDC
iFi Audio GO BLU AIR
The Go Blu Air is connected via its two outputs: a 3.5mm jack using S-Balanced technology and delivering up to 165mW at 32Ω, and a second balanced 4.4mm jack delivering up to 262mW at 32Ω. Power is supplied via a USB-C port, which charges the battery and provides up to 10 hours of battery life.
iFi Audio Go Blu Air: A high-performance DAC
The Go Blu Air’s unique design reveals the components essential to its performance, each one separate and dedicated to a specific task. Its Qualcomm QCC5144 chip handles Bluetooth reception, while the Cirrus Logic CS43131 DAC chip handles signal conversion. A dual-stage amplifier handles a balanced 4.4mm jack output of up to 256mW/5.6V as well as an S-Balanced 3.5mm jack output. The GMT clock system, meanwhile, enables a drastic reduction in jitter. Finally, XBass and XSpace technologies deliver punchy bass and an immersive soundstage, respectively.
The inclusion of Bluetooth 5.2 connectivity enables convenient wireless use. It supports high-performance codecs such as LDAC, LHDC, and aptX.
iFi Audio GO BLU AIR: A high-performance DAC
iFi Audio GO BLU AIR: A portable design
iFi Audio Go Blu Air: A portable design
The Go Blu Air comes with a detachable magnetic clip, allowing you to carry it safely and easily by attaching it to a belt, bag or pocket; thanks to its lightweight design, weighing just 30g, it won’t get in the way.
In addition, it features a MEMS microphone with noise cancellation powered by Qualcomm technology, enabling clear hands-free calls. Its rotary knob allows you to adjust the volume by turning it. A short press controls play/pause, as well as fast-forward and rewind. Finally, a long press of the button activates the voice assistant on the connected smartphone.
Product typePortable DAC and headphone amplifier
Inputs1x USB-C (charging)
Bluetooth 5.2
Outputs1x 3.5mm Jack S-Balanced
1x 4.4mm Jack Balanced
DAC ChipCS43131
Bluetooth chipQualcomm QCC5144
Bluetooth codecsLDAC, LHDC/HWA, aptX Adaptive, aptX HD, aptX, AAC, SBC
Supported sampling ratesUp to 24bit 96kHz (LDAC)
Impedance1Ω
SNR≥ 110dB
Battery life10h
BatteryEnviron 450mAh
Performance of 3.5mm S-Balanced headphone jack output
Output power≥ 165mW/2.3V @ 32Ω
≥ 14mW/2.9V @ 600Ω
THD+N≤ 0.03% @ (16Ω, 1.27)
Performance of 4.4mm balanced headphone jack output
Output power≥ 262mW/2.9V @ 32Ω
≥ 52mW/5.6V @ 600Ω
THD+N≤ 0.009% @ (600Ω, 2V)
Dimensions53.5 x 33.7 x 19.5mm
Weight31g
Package1x iFi Audio Go Blu Air
1x USB-A to USB-C cable
1x Microfibre protective bag
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rate96kHz
ColorBlue
Great and small device
Great device, tested out only the 3.5mm jack. Plays loudly and cleanly on Crinacle zero Red.
The only drawback is that the volume wheel ignores input if turned too quickly. About 1 revolution per second is its maximum speed, anything faster and the volume barely moves, so you need to be patient when you need to adjust the volume quickly
This review has been posted for IFI AUDIO GO BLU AIR Portable DAC Headphone Amplifier CS43131 Bluetooth 5.2 aptX Adaptive LDAC LHDC
The iFi Audio GO Blu Air is a portable Bluetooth DAC and headphone amplifier designed to follow you everywhere. Both practical and...
