LV1084 20V / 5A Dual Controlled Linear Power Supply Module
3.0 / 5
Reference : 8426
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 16-04-2026.
Its particularly rigorous design and the quality of its components make it an excellent choice for powering any type of module or audio components requiring low voltage and clean power.
As many environments in which it contributes to improve the sound quality, equipped with two potentiometers it is possible to adjust its voltage from 2.5 to 35V.
Features:
  • Integrated discharge resistance
  • Output voltage adjustable with potentiometers
  • Input voltage: 2.5 to 17V AC
  • Output Voltage: Variable from 2.5 to 24V
  • Max. Output current: 7.5A (theoretical data depending on dissipation)
  • BC Capacitors: 8 x 1500 μF 35V
Physical characteristics:
  • Height: 54 mm
  • Dimensions: 126 x 90 mm
  • Fixing holes: 82 x 118 mm
  • Weight: 240 g
https://www.audiophonics.fr/images2/8426/8426_LINEAR_PSU_LT1083_1.jpg
https://www.audiophonics.fr/images2/8426/8426_LINEAR_PSU_LT1083_2.jpg
Diagram:
https://www.audiophonics.fr/images2/8426/8426_LINEAR_PSU_LT1083_3.jpg
InputScrew terminals
OutputScrew terminals
Output voltage (V)20.0
Output current (A)5.0
Input voltage (V)5.0
Input voltage (V)15.0
Input voltage (V)3.0
Input voltage (V)10.0
Input voltage (V)17.0
Power SupplyRegulated Linear Power Supply
2 reviews
Description à revoir
Pas possible de sortie des tensions inférieurs à 5vdc contrairement à ce que vous indiquez
This review has been posted for LV1084 20V / 5A Dual Controlled Linear Power Supply Module
DIfferent from the one illustrated
Once received the item, it seems "old" and a bit rusty and with different components than the ones in the website photos. A 10k resistance was cracked (not a grat problem, substituted). The most great difference (or problem) is in the capacitors bank. the PCB reports "10000uF", but in web photo we have 2200 uF x4 x Channel (quite near) and mounted I founded 1500 uF x4 xChannel, which is quite half than declared. Volt for capacitor is also different (35V instead of the illustrated 25V and that could be better). Also diodes are not the illustrated one (they are Motorola MBR1645 in a TO220 package).
I know these items are not produced by Audiphonic, but a more deep control of conformity may be in result of a better service. It's functional but I'm not so satisfacted. Sufficient but not more.
Marco
 (8)
