AUDIOPHONICS PSM2 Ignition Management Module 220V 30A
AUDIOPHONICS PSM2 Module de Gestion d'allumage 220V 30A
Reference : 6356
29,90 €tax incl.
24,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This module is intended to control the lighting order of the various components of an audio system.
It is used to control the delayed power supply of the amplifier after switching on the preamplifier and vice versa when the power is turned off (this function is also useful for turning on a source before its amplifier).
The triggering of this module can be carried out in several ways, by push button, switch or Trigger (this module is also directly controllable by our PGAVOL).
The relays integrated in the module can supply two lines of 110 or 220 V at 30 Amps.
The different delay settings are obtained by means of DIP Switch:
  • Switches from 1 to 3 (SW1-3) control the switching on of the second device (adjustable from 0 to 7 seconds in steps of 1 second).
  • Switch 4 (SW4) switches on the first device (it only has two states 0 sec OFF and 2 sec ON)/ Li>
Detail of the ignition timing of the second device:
  • SW1 = 1 sec
  • SW2 = 2 sec
  • SW3 = 4 sec
For example,https://www.audiophonics.fr/images2/6356/6356_AUDIOPHONICSPSM2_Switch.jpgwe see switches 1 and 2 in ON and switch 3 in OFF, here the default delay is 3 sec (1 + 2).
The 3 different entries are:
  • Sw = Switching
  • PB = Push Button or Reset Button
  • MC = Trigger (from 2.4 to 12V)
psm2 trigger polarity
Features:
  • Compatible with 110 V
  • Dimensions: 100 x 90 x 30 mm
  • Mounting hole spacing: 90 x 80 mm
  • Lugs required: 6.5mm internal width
https://www.audiophonics.fr/images2/6356/6356_AUDIOPHONICSPSM2_2.jpg
https://www.audiophonics.fr/images2/6356/6356_AUDIOPHONICSPSM2_1.jpg
Module très utile
J'ai fait l'acquisition de 3 de ces modules, on peut simplement regretter que le prix ait sensiblement augmenté (à l'origine 21 puis 25 puis 35 €). Ceci étant, ce genre de produit est vraiment intéressant dans une installation audio/vidéo. On a le choix du mode de déclenchement, ce qui est vraiment fondamental. Pour ma part, j'utilise généralement le mode "bouton poussoir" mais pour mon système home cinéma il sert d'interface secteur et est déclenché par la sortie "Trigger 12V DC" de l'ampli AVR.
This review has been posted for AUDIOPHONICS PSM2 Ignition Management Module 220V 30A
