ELECAUDIO TE-RC85S RCA Plugs Tellurium Copper Gold Plated Ø8.5mm (Pair)
4.4 / 5
Reference : 9045
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 22-09-2026.
These connectors have been designed to offer you a high conductivity thanks to Copper Tellurium.
By way of comparison, the majority of the connectors on the market are based on Brass or Bronze alloys having a conductivity index (IACS) of 56%, compared with 98 to 99% for Cu Te.
Specifications:
  • Center pin and Tellurium plated copper ground pole 24K gold nickel free
  • ABS base
  • POM coating (Polyoxymethylene)
  • Acceptable Cable Diameter (Solder): 8.5mm
  • Overall length: 44mm
  • Total diameter: 13mm
  • Weight: 0.010kg / unit
  • Sold by pair
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
21 reviews
Great value
These are the cheapest rca plugs I have used for my diy cables. Normally I buy Klei but these seem to be a similar design concept so thought I give it a shot considering I was using a pretty standard cable. While they are not on the same level as the Klei plugs, they are still very good for the cost. I used them with mogami 2549 cable and together they make a great low budget cable. They sound smooth and relaxed, so understand why some feel there’s something missing, but to me they sound very natural on my setup with great stereo separation. I can recommend these as a cheap but good rca plug.
This review has been posted for ELECAUDIO TE-RC85S RCA Plugs Tellurium Copper Gold Plated Ø8.5mm (Pair)
top
ces fiches rca sont parfaites en tous points. faciles a souder, légères et peu encombrante et transmission du signal intègre.
elles font souvent partie des choix des grandes marques de câbles.
Parfaite
Excellentes fiches RCA, simple efficace et agréable a travailler et au rendu sonore
Pour 3 euros de plus...
Utilisées depuis longtemps suite a la lecture de bons avis sur ces fiches j'ai décidé d'en avoir le cœur net. Testée comparativement avec les fiches plus classiques du même fabricant ELECAUDIO RC-602 sur le même câble (occ crystal). Résultat immédiat : l'image sonore s'agrandit et ca respire beaucoup plus, avec de jolies extinctions de notes. J'ai aussi trouvé les timbres plus riches voir même un poil brillants, tout dépendra finalement de l'association avec le reste. Le retour aux RC-602 est compliqué... C'est fade, plat et l'extrême grave est en retrait.
Attention quand même au corps en plastique très fragile de ces fiches, très faciles a souder au demeurant. Le moindre coup de fer a souder de travers et hop on entame le filetage, ce qui rend impossible le vissage du corps. A part ce détail excellent produit agréable a utiliser au quotidien. Merci Elecaudio, un tel apport technologique pour un budget si faible est clairement significatif.
Poor higher tones
Unfortunatelly, I can only confirm some previous comments. I bought 12 of them, 4 were used with Mogami 2549, 4 with Canare 4e6s, on both very poor results in higher tones. 4 will remain unused. Cables were made by devoted audiophile who owns workshop which is also authorised repair service for Bang and Olufsen, Bose, ... My worst 'audiophile' purchase so far. Sorry to write this I was really looking forward to them.
Higher tones are supressed, no joy in listening music through these connectors. I should have gone for Neutrik or Klei. Money lost. I will probably buy Klei.
