This USB 2.0 Micro SD card reader makes it quick and easy to transfer content to or from a Micro SD card. Thanks to a USB-A port, it can also be used to connect peripherals such as keyboards, mice, joysticks, WiFi USB sticks and USB hard drives.
The OTG function can only be applied to one connector at a time (Micro SD or USB-A 2.0).
Product type | Micro SD / USB-A adapter |
Connectors | 1* Female USB-A port 1* Micro SD slot 1* Male USB-A 2.0, convertible to male Micro USB 1* Male USB-C |
Dimensions | 18.3*73.5mm |
Color | Black |
Weight | 10g |
Connectic | Male & Female |
Connector | USB-A |
Connector | USB-C |
Connector | Micro USB |
Connector | Micro SD |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
