By buying this product you get 59 loyalty points
The MAESTRO speaker can be used in true stereo. Simply pair 2 speakers using the Virtuose application.
Connected Active Speaker Bluetooth WiFi AirPlay 2 Light Wood
With the Maestro, Octavio unveils a superb connected active speaker, capable of delivering uncolored sound with a wide soundstage and beautiful richness. The Maestro speaker connects via Bluetooth and WiFi for lossless listening and maximum versatility, allowing you to enjoy your music from all the major streaming platforms or access files stored on your networked devices. It's compatible with AirPlay 2, Spotify Connect and Tidal Connect streaming protocols. In addition, two Maestro speakers can be connected together wirelessly to create a stereo system.
The Octavio Maestro uses Davis Acoustics speakers with Kevlar diaphragms, ensuring a very precise sound reproduction. Light and rigid, the models used offer a beautiful musicality, with soft mids, deep bass and particularly well defined highs.
In addition to its wireless connectivity, the Maestro speaker can also be connected in the traditional way thanks to its Jack 3.5mm and Optical Toslink connectors. It is thus possible to connect any audio equipment.
Thanks to the Octavio Virtuose mobile application, you can access all your music directly from your favorite streaming platforms and web radios as well as all your local files. More than that, the application offers the possibility to define an equalizer and to create profiles to easily adapt the sound reproduction of your speaker.
| Specifications | |
| Product type | Connected active speaker |
| Drivers diameters | Woofer: Ø13cm Tweeter: Ø2.5cm |
| Frequency response (-3dB) | 40Hz - 20khz |
| Output power | 70W |
| Amplification type | Class D |
| Supported wireless protocols | Spotify Connect Tidal Connect AirPlay 2 Bluetooth |
| Connectors | 1* Jack 3.5mm 1* Optique Toslink 1* Ethernet RJ45 |
| Audio resolution | 16bit 48kHz |
| WiFi | WiFi b/g/n 2.4GHz/5GHz |
| General | |
| Consumption | In use: 14W En Standby: 1.9W |
| Dimensions (L*P*H) | 31.5*28.5*27cm |
| Weight | 3.45kg |
| Color | Light wood |
