TRIANGLE BOREA BR03 BT Active Bookshelf Speakers Bluetooth 5.0 aptX HD 2x60W Light Oak Blue (Pair)
The Triangle Borea BR03 BT active speakers are a powerful and efficient all-in-one HiFi system with multiple and practical features. They have been designed for a versatile use, perfectly adapting to today's needs. In this spirit, the BR03 BT integrate a high definition Bluetooth aptX reception function for remote broadcasting, allow the connection of a vinyl turntable thanks to the phono input, have an optical input for association with a TV and even provide a subwoofer output, offering the possibility of associating a subwoofer (not supplied).
By buying this product you get 59 loyalty points
Reference : 16480
599,00 €tax incl.
499,17 € tax excl.
Triangle Borea BR03 BT Enceintes Bibliothèques Actives Bluetooth 5.0 aptX HD 2x60W Chêne Clair Bleu (La paire)
True integrated HiFi system, the BR03 BT embeds a Class D amplifier capable of delivering a comfortable power of 2x60W RMS. Each speaker is equipped with an EFS fabric dome tweeter and a 16.5cm diameter bass-midrange driver. Thus, these bookshelf speakers, although compact, are able to develop a rich sound image, marked by powerful and controlled bass, soft mids and accurate highs.
Positionable on a piece of furniture or dedicated supports, the BR03 BT are able to sound large rooms, up to 40m². A radio remote control is also provided, with a range of more than 15m, allowing a remote control.
High-end design
The Borea BR03 BT is constructed of high density wood and equipped with the latest generation of Triangle drivers. All Borea loudspeakers benefit from the technological and acoustic innovations of the Esprit Ez series, including the cabinetry and the driver cones.
EFS Tweeter :
The tweeter equipped in the speakers of the Borea range benefits from a new generation system called EFS (Efficient Flow System). This system is based on the combination of a 25mm silk dome known for its neutrality, and a phasing piece, specifically developed to homogenize the diffusion of high frequencies. This system drastically reduces the directivity factor, regardless of where you are listening in the room. The driver's diaphragm is placed inside a horn cone, limiting edge effects for a clear high-frequency sound reproduction. This transducer is powered by a neodymium magnet motor, capable of generating a large magnetic power for a small footprint. It is associated with a heat sink to guarantee a better power handling.
Medium in natural cellulose:
The Borea range uses a midrange driver with a 100% natural cellulose pulp membrane that does not undergo any surface treatment. This avoids any coloring of the intermediate frequencies in order to reproduce voices with realism, while offering a characteristic grain of the most beautiful effect. The profile of the membrane has been reworked to increase the rigidity of the speaker and improve its frequency response.
Percussive bass:
Triangle focuses on fast and accurate bass drivers, using a large motorization and placed in a specially optimized cabinet. The result is a punchy and immediate bass that promotes a controlled rhythmic reproduction. The bass transducers integrated here use a glass fiber membrane. This material ensures a high impact force, without impinging on the vocal register and the overall coherence.
DVAS system:
Following extensive research to reduce internal vibrations related to the cabinet, the Borea range of loudspeakers incorporates openwork internal panels made of MDF and EVA foam to stiffen the transducer and cabinet assembly. This process reduces structural vibration while absorbing low frequency vibrations.
This proprietary system, developed by Triangle and named DVAS (Driver Vibration Absorption System), uses a high-density EVA foam gasket at the end of each internal bracing, ensuring perfect contact between the driver and the bracing, thus greatly attenuating the vibrations generated by the driver, which only transfers a small amount of vibration to the cabinet. This DVAS system ensures a high degree of neutrality and clarity, without sound coloration.
Decoupling :
Each speaker of the Borea range has its own decoupling system. The BR03s are delivered with rubber pads, protecting the underside of your speakers, but also limiting the transmission of vibrations.
Magnetic cover :
All Borea loudspeakers have a magnetic protective cover, leaving no screws or inserts visible.
Wireless reception
The Triangle Borea BR03 BT speakers benefit from a Bluetooth 5.0 reception allowing you to broadcast your music remotely, from a smartphone or a tablet for example. The support of aptX, aptX LL and aptX HD codecs offers the possibility of a high quality wireless transmission with a sampling rate of sources up to 24bit 48kHz.
Don't put your vinyl in the closet
The BR03 BT are also designed to allow you to enjoy your vinyl collection. Thus, these speakers include an MM phono preamplifier and a phono input, allowing you to connect a turntable directly to them without the need for additional equipment.
Simply enjoy your vinyl
The Borea speakers are also at ease as a complement to an audio-video system, offering an excellent sound immersion. It is thus possible to connect a television set directly to them thanks to the integrated optical input or a video player using the coaxial input. The BR03 BT also allows the association of a subwoofer, such as the Triangle Tales 340 (sold separately), for a more important low frequencies.
Attention to detail
Here, every detail has been refined and optimized for the most compelling HiFi experience possible, both in terms of design and performance. The speakers come with a radio remote control for easy remote control. A discreet LED in the corner of the speaker indicates the active source with a simple color code.
Triangle Borea BR03 BT Enceintes Bibliothèques Actives Bluetooth 5.0 aptX HD 2x60W Chêne Clair Bleu<span id= (La paire)" />
Product typeActive bookshelf speakers
Speaker typeBass Reflex
Number of ways2
LoudspeakersTweeter Ø25mm
Medium-Bass Ø16cm
Sensitivity90dB/W/m
Amplificatoin typeClass D
Power handling2x60W RMS
Frequency response47Hz - 22kHz
Min/Max nominal impedance4.2Ω / 8Ω
InputsBluetooth 5.0
1x Jack 3.5mm
1x Optical Toslink
1x Coaxial
1x Stereo RCA (Line / phono MM)
Output1x Subwoofer output (RCA)
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Supported audio formatsMP3, WMA, APE, FLAC, WAV, Apple Lossless
Dimensions206 x 360 x 314mm
Weight (pair)14.2kg
ColorLight Oak Blue
Package2x Borea BR03 BT
1x Remote control
1x Power cable
1x Speaker cable 3m
ColorLight Oak
Impedance (Ω)4
Impedance (Ω)8
Efficiency / Sensitivity (dB)90.0
Lowest frequency (Hz)47
Highest frequency (Hz)22000
Power (W)60.0
Number of ways2
Speaker typeActive
Speaker form factorBookshelf speaker
The Triangle Borea BR03 BT active speakers are a powerful and efficient all-in-one HiFi system with multiple and practical features. They have been...
