The Yamaha NS-SW050 active subwoofer is a bass-reflex model equipped with a 50W amplifier stage and a 20cm subwoofer. Its side-mounted Twisted Flare Port is optimized for perfect airflow and punchy bass. The subwoofer also benefits from Yamaha's proprietary Advanced YST II (Yamaha Active Servo Technology II) for excellent driver control and linear response from 28Hz to 200Hz. This model is therefore ideal for integration into a small or medium-sized HiFi or home-cinema system, to enjoy deeper bass and greater immersion in your music or films.
In terms of connectivity, the Yamaha NS-SW050 subwoofer is equipped with an LFE input (mono RCA), so it can be combined with a system featuring a preamplified subwoofer or LFE output. The rear panel also features a volume control knob.
Product type | Active subwoofer |
Load type | Bass-Reflex |
Driver diameter | Ø20cm (8") |
Frequency response | 28Hz-200Hz |
Vent position | Lateral |
Power | RMS : 50W (100Hz, 5Ωn 10% THD) Max :100W (5Ω) |
Volume control | |
Connectivity | 1x LFE (RCA) input |
Dimensions (W x D x H) | 291 x 341 x 292mm |
Weight | 8.5kg |
Color | Noir |
