produit conforme à la description, seule petite différence esthétique au niveau du bouton rotatif mais je trouve celui que j'ai reçu plus joli que celui de l'illustration ! très belle qualité d'usinage, emballage parfait.
Aluminium box 260x170x65mm Silver
This 100% Aluminium DIY case with its sleek design is equipped with non-slip feet.  It will allow you to integrate a preamplifier, a source selector or any other audio setup.  Its original design assures you a professional and robust assembly and finish.
The pre-drilled holes at the back have a diameter of 11mm.
Case delivered unassembled.
| Specifications | |
| Product type | DIY Case |
| Internal dimensions | Width: 158mm Depth: 250mm Height: 58mm  |
| External dimensions | Width: 170mm Depth: 260mm Height: 65mm  |
| Material | Brushed solid aluminium |
| Panel thickness | Front: 8mm Rear: 3mm  |
| Weight | 1.4kg |
| Color | Front: silver Other parts: black  |
| Package | Case Screws Non-slip feet IEC plug ON/OFF switch Button  |
Average votes  5.0 / 5  4 reviews  | Why write products reviews ?  You can share your feelings about products and help other people by sharing your experience  |
Xavier M.
Jean Pierre D.
Jam M.
Philippe P.
