By buying this product you get 22 loyalty points
The EarAcoustic Genesis G318s are dynamic driver in-ear monitors designed to deliver a structured and nuanced reproduction across the full frequency spectrum. They rely on a titanium diaphragm paired with a diamond nanoparticle-coated composite suspension, along with a dual opposing magnet architecture, in order to stabilise driver behaviour while maintaining accurate high-frequency reproduction and coherent bass control.
The Genesis G318s integrate a dynamic driver whose titanium diaphragm prioritises high rigidity, limiting deformation under transient conditions while maintaining precise high-frequency reproduction. This approach is further extended by a diamond nanoparticle-coated composite suspension, whose mechanical properties reduce energy loss in the bass and midrange, stabilising diaphragm movement across the full usable range.
Beyond materials, the dual opposing magnet architecture establishes a more homogeneous magnetic field around the voice coil, linearising the motor force while reducing distortion caused by flux variations.
The Genesis G318s rely on a two-layer tuning approach, combining a frequency correction foundation with targeted harmonic shaping. The first layer aims to establish a globally neutral response, ensuring a balanced energy distribution across the frequency bands, allowing for a clear and readable reproduction of the source material.
Building on this, a second layer introduces an intentional coloration, characterised by a moderate bass reinforcement and a relative attenuation of the high frequencies, orienting the overall signature toward a denser and smoother rendering. This superposition maintains tonal coherence while imparting a more organic quality to the listening experience.
The aluminium housing is machined using 5-axis CNC, enabling complex geometries that would be difficult to achieve with more conventional processes, while ensuring a rigid structure that limits parasitic resonances and maintains stable driver positioning. This foundation is further refined through hand polishing, which homogenises the surface across the varying relief, preparing the part for the final finishing treatments.
An electroplating process is then applied to stabilise the surface finish while reinforcing resistance to wear, visually unifying forms that are deliberately unconventional.
The Genesis G318s are supplied with a CIEM to 3.5mm jack cable made from silver-plated OFC copper, ensuring high-quality signal transmission to fully exploit the performance of the earphones.
| Specifications | |
| Product type | In-ear monitors |
| Drivers | 1x Dynamic driver Ø8.3mm |
| Impedance | 38Ω |
| Sensitivity | 110dB |
| Frequency response | 20Hz-20kHz |
| Cable | Detachable |
| Earphone connectors | 0.78mm 2 pins |
| Cable termination | 3.5mm jack |
| Cable material | Silver-plated OFC copper |
| General | |
| Colour | Silver |
| Package contents | 1x EarAcoustic Genesis G318s 1x 3.5mm to 0.78mm 2 pins cable 1x Carrying pouch |
| Color | Silver |
| Impedance (Ω) | 38 |
| Efficiency / Sensitivity (dB) | 110 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
