I tried other TPA 3116/3118 amps, that all suffered from an audible hiss. This one is really quiet.
Bluetooth connection is automatic and fast.
I have been able to power it from 8 volt to 20 volt without issue
This extremely compact amplifier bluetooth module receives dematerialized digital input stream and outputs a single amplified output signal.
It operates a class D amplifier TPA3118D2 chip mounted in bridge, allowing it to deliver considerable power 30W while retaining very advantageous dimensions and without requiring sink. It also benefits from superior performance to 90% making it an amplification solution tailored for compact projects.
The module finally shows its ease of integration: the power connector and the amplified audio output connector are already materialized on the PCB via connectors like Phoenix. The supply circuit for its part offers a wide range of options with compatibility with voltages from 12 to 24V for an intensity of 3A.
The module has extremely small dimensions.
The PCB has only one hole for mounting. The latter is located on the connectors side to stabilize the module where the tension would occur if the cables were accidentally pulled.
Type | Module amplification |
Inputs | Bluetooth |
Outputs | Screw terminals |
Power | 12 to 24V DC |
Class | D |
Amplification Chip | TPA3118D2 |
Power | 30W / 8Ω |
Channels | x1 (mono) |
Dimensions | 31 x 50 x 17mm |
Input | Bluetooth |
Output | Screw terminals |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TPA3118 |
Power (W) | 30.0 |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Henrik S.
Vincenzo C.
Dario G.
Franck B.
FREDERIC C.
