ARYLIC UP2STREAM AMP V4 Amplifier Board Stereo / Mono Bluetooth 5.0 WiFi 2x50W / 1x60W 4 Ohm
The Arylic Up2Stream Amp V4 is an extremely practical stereo amplification module. Taking advantage of Bluetooth 5.0 and WiFi connectivity, it allows you to broadcast your music remotely, from a smartphone, a computer or a NAS. Capable of developing a power of 2x50W under 4Ω, the Up2Stream Amp V4 is ideal for the design of a multi-room audio system.
Reference : 14995
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 07-04-2026.
Arylic Up2Stream Amp V4 Module Amplificateur WiFi Bluetooth 5.0 2x50W 4Ω
The Arylic Up2Stream Amp V4 is an amplifier module that can operate in stereo or mono mode. With Bluetooth 5.0 and WiFi connectivity, it allows you to stream your music remotely from a smartphone, computer, or NAS. Capable of delivering 2x50W or 1x60W of power into 4Ω, the Up2Stream Amp V4 is ideal for designing a multiroom audio system.
PC support & configuration software
The Arylic Up2Stream Amp V4 can be connected to a computer via its Micro USB port to act as an external DAC. It is also possible to use the ACPWorkbench software to customize the different frequency and EQ settings.
Numerous expansion ports
The module offers one I2S digital output and one DAC analog output. These will allow you to connect other amplifiers to create a more complex system that is perfectly adapted to your needs.
Mono / Stereo Switch
The Up2Stream Amp V4 can operate in mono or stereo mode. Selecting one of these modes is simple, via a jumper. In stereo mode, the Amp V4 is capable of delivering 2x50W into 4Ω. In mono mode, it can deliver 1x60W into 4Ω.
Set up your multiroom system
If you have an audio system in several rooms of your house, you can connect as many Arylic Up2Stream Amp V4 to form a multi-room audio system. You will be able to broadcast your music throughout your house in synchronization.
All your favorite streaming services
The Arylic Up2Stream Amp V4 is compatible, via its free 4Stream application, with many streaming services: Qobuz, Spotify, Deezer, Tidal, Napster or web radios. The module also allows you to play your files locally, from a NAS or directly from a USB storage device.
4Stream App
The 4Stream application, available for free on Android and iOS, will allow you to easily and remotely control the playback on your different Arylic Up2Stream Amp V4 modules.
Application 4Stream Android Play Store Application 4Stream iOS App Store
Product typeAmplifier module
Amplification typeClass D
Inputs1x Jack 3.5mm
1x 4 pins connector
1x Micro USB
1x USB-A Host
1x RJ45 Single 10/100M
OutputsSpeaker output (5 pins connector, 5mm spacing)
Wireless connectivityBluetooth 5.0
WiFi IEEE802.11 b/g/n 2.4G
Supported Bluetooth codecsSBC, AAC
Bluetooth transmission distance10m
Power output (stereo)2x 50W @ 4Ω, BTL, 21V
2x 30W @ 8Ω, BTL, 24V
2x 15W @ 8Ω, BTL, 15V
Power output (mono)1x 100W @ 2Ω, 24V
1x 60W @ 4Ω, 21V
1x 30W @ 8Ω, 18V
THD0.03% @ 1kHz, 2x50W, 24V, 4Ω
Speaker impedance4-8Ω
Supported file formatsFLAC, MP3, AAC, AAC+, ALAC, APE, WAV
Supported sampling ratesPCM up to 24bit 192kHz
Supported WiFi protocolsAirPlay, DLNA, UPnP, Spotify Connect, Qplay
Power supply12-26V DC (sold separately)
Dimensions110 x 80 x 22mm
Package1x Arylic Up2Stream Amp V4
1x Screwdriver
1x 4 pins analog connector
2x Antennas
InputJack 3.5mm
InputWiFi
OutputWiFi
OutputBluetooth
OutputSpeaker terminal
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipN/A
Power (W)50.0
Up2stream amp v4
Super ampli. N'hésitez pas à le refroidir avec un ventilateur si vous le mettez dans une boîte grâce à ces connecteurs +5v et GND
Je n'ai pas reçu le connecteur vers pour brancher les baffle donc je vais devoir faire de la soudure. N'hésitez à acheter la télécommande avec car elle permet de faire plein de choses sans sortir son téléphone
This review has been posted for ARYLIC UP2STREAM AMP V4 Amplifier Board Stereo / Mono Bluetooth 5.0 WiFi 2x50W / 1x60W 4 Ohm
The Arylic Up2Stream Amp V4 is an extremely practical stereo amplification module. Taking advantage of Bluetooth 5.0 and WiFi connectivity, it...
