AUDIOPHONICS TA2022 V4 Amplifier Module Tripath 2x90W 4 Ohm
10%
Based on the T-Class architecture of the famous TRIPATH brand, this AUDIOPHONICS amplifier module features high quality reproduction for a very compact product.
4.6 / 5
Reduced price!
Reference : 4604
Limited time offer:
89,00 €tax incl.
-10%
80,10 €tax incl.
66,75 € tax excl.
Shipping date: 17-07-2025.
Audiophonics TA2022 V4
Amplifier module TRIPATH 2x90Watts
Audiophonics TA2022 V4 Module Amplificateur TRIPATH 2x90Watts
This new version uses more surface components, and a revised power supply (single diode bridge for ground loops). The input stage now accepts RCA and XLR signals with an AOP 5532. Based on the T-Class architecture of the famous TRIPATH brand, this AUDIOPHONICS amplifier module features high quality reproduction for a very compact product.
The integrated TA2022 chip can indeed reach 2 x 90 Watts under 4Ω with an extremely well controlled harmonic distortion level since not exceeding 0.1%. A power that in no way sacrifices to the precision of this prodigious circuit renowned connoisseurs for its musical virtues.
To protect your speakers, this board has a protection circuit against the possible presence of a DC component. A delay time also prevents unpleasant ignition noise. Jumpers are used to select the input: balanced (XLR) or unbalanced (RCA). This version is bridgeable to reach up to 150W under 4ohm.
Output power per channel60W 8 Ohm (@ THD+N 0.1%)
90W 4 Ohm (@ THD+N 0.1%)
Bridge output power150W 8 Ohm (@ THD+N 0.1%)
THD0.015% @ 45W 8 Ohm
0.015% @ 70W 4 Ohm
SMPTE0.10 @ 25W 4 Ohm
Dynamic range102dB
Efficiency92% @ 88W 8 Ohm
87% @ 125W 4 Ohm
Power suppltTransformateur 2x20V or 2x20V 2.6A + 1x12V 1A + 1x9V 1A of 100-160VA
Dimensions200 x 80 x 35mm
Space between fixation holes70 x 190mm (M4)
Weight240g
Two feeding options
  1. Transformer 2 windings (For example 2x20V : 4104)
  2. Transformer 4 windings (For example 2x20V + 12V + 9V: 8710)
Détail des entrées AC :
  • AC power : 2x20V
  • AC1 : 9V
  • AC2 : 12V
Balanced input: 9-pin connector
Selected unbalanced input: 3-way terminal block
IMG_9161-1.jpgschéma cablageaudiophonics_TA2022_schema.jpgTA2022_connection_ok.jpg
InputScrew terminals
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTA2022
Power (W)90.0
9 reviews
TA 2022 amplificateur TRIPATH
Module de valeur, mais dommage que les borniers ne soient pas a la hauteur du résultat d'écoute en enceinte assistée
This review has been posted for AUDIOPHONICS TA2022 V4 Amplifier Module Tripath 2x90W 4 Ohm
module de valeur mais dommage que les borniers ne sont pas a la hauteur du résultat d'écoute
Bon pour la musique
Ce composant amplificateur TA2022 module très bien des enceintes présentant une impédance chaotique. Il remplace avantageusement les montages classe AB capables de fournir de forts courants.
un module qui mérite sa réputation...
Acheté presque par hasard, ce module a tout de surprenant même si sa réputation en terme de musicalité est établie.
CI de qualité + facilité de connections + tuto audiophonics bien fait, tous est réuni pour préparer facilement son nouvel ampli sans difficulté.
Le réglage offset n'a pratiquement pas besoin d'être retouché, preuve que le module a été testé au préalable.
Enfin, connections faites, tension ON, c'est un régal. Beau son, ampleur sur tout le spectre, basses bien présentes, médium parfait, aigus en finesse et ce sur deux types d'enceintes large bande en 4 et 8 ohms.
Que des compliments pour un rapport qualité prix sans égal.
A noter, strictement aucun bruit de fond, mais aucun, soit mieux que les caractéristiques techniques.
Facile, beau son, prix très abordable, que demander mieux.
un must have !
Configuration :
Quatre modules TA2022 V4 et deux modules LJ TA2022 V1.2 avec leur alimentation torique séparée. Le tout placé derrière un filtrage actif assuré par le Behringer DCX 2496.
Deux des modules TA2022 V4 sont bridgés et alimentent chacun un HP Monacor SP 382 PA de 38cm
Deux des modules TA2022 V4 alimentent chacun deux H.P chargés de restituer les mediums. Un Davis 17CSA et un Peerless 833599 sont connectés respectivement sur les sorties droite et gauche de chacun de deux modules.
Enfin, les deux modules LJ TA2022 V1.2 alimentent chacun un Tweeter Monacor DT-280. L’une des sorties est neutralisée.
Calibrage :
Les 38cm de Monacor nécessitent beaucoup de puissance pour répondre promptement, d’où les deux amplis bridgés. Malgré la puissance annoncée de 100W sous 8 Ohm, une correction du gain de +4db a été nécessaire pour remettre le HP de graves au niveau des autres.
Les deux médiums quant à eux ont été corrigés à -0.5db et se contentent largement des 2X60W sous 8Ohm délivrés par les deux TA2022 V4.
Les Tweeter très puissants sont corrigés à -2.5db et alimentés par la LJ TA2022 V1.2 dont l’une des sorties a été neutralisée.
Ecoute :
Malgré mon appréhension, le 38cm est bien maitrisé, sec, précis, même lors des gros solos de batterie. Il répond promptement, que le niveau sonore soit élevé ou faible. Le module TA2022 V4 n’est jamais à la traine et pourtant, les Monacor de 38cm utilisés pour ce test sont surtout utilisés en sono et n’ont pas la réputation d’être particulièrement précis et dociles. Bref, le module TA2022 V4 fait montre d’une belle énergie jusque dans les extrêmes graves.
Les medium sont précis, bien définis, ils brillent par leur neutralité. Le gros point fort porte sur les voix, d’une véracité bluffante. Le module TA2022 V4 se montre d’une neutralité étonnante. Pour un peu on cherche où se cache le ou les chanteurs. Sur les grosses formations orchestrales, le module TA2022 V4 de démérite pas, chaque instrument trouve sa place dans la scène sonore.
Quant aux aigus, mazette, ça sonne juste, terriblement juste. Jamais agressifs, d’une précision chirurgicale mais jamais fatiguants même après de longues heures d’écoute.
La spacialisation de la scène sonore est très crédible. Précise et rigoureuse.
En conclusion, Le module 2022 souffre d’un manque de peps dans les extrêmes grave en filtration passive, aussi je conseille de l’utiliser en multi amplification. C’est précisément dans ce type de configuration que ce module trouve tout son intérêt et peut donner le meilleur de lui-même.
Pour moins de 1000€ et avec un peu d’huile de coude, il est possible de monter un système multi amplifié qui sonne à en faire pâlir bien des amplis du marché pourtant vendus dix fois plus chers. Une véritable aubaine pour qui veut se lancer dans l’aventure. Un must have !
Service après-vente d’Audiophonics au top. L’un de mes modules LJ TA2022 V1.2 avait grillé, la puce TA2022 a été remplacée par le S.A.V. et le module réparé renvoyé sous deux semaines.
Based on the T-Class architecture of the famous TRIPATH brand, this AUDIOPHONICS amplifier module features high quality reproduction for a very...
