Class D Amplifier Module Infineon MA12070 Bluetooth 5.0 2x35W 4 Ohm
This small Class D amplifier module uses an Infineon MERUS™ MA12070 amplifier chip allowing it to develop a power of 2*35W under 4Ω (1% THD+N) while offering a high efficiency and a precise and detailed sound reproduction.
Reference : 17099
22,90 €tax incl.
19,08 € tax excl.
Amplifier module
Infineon MA12070 Bluetooth 5.0 2*35W 4Ω
Module amplificateur Infineon MA12070 Bluetooth 5.0 2*35W 4Ω
This small, high-performance Class D amplifier module uses an Infineon MERUS™ MA12070 amplifier chip allowing it to develop a power of 2*35W under 4Ω (1% THD+N) while offering high efficiency and precise and detailed sound reproduction. The module provides a USB-A input to connect a storage device such as a USB key or an external hard drive, but above all has a Bluetooth 5.0 receiver as well as a 3.5mm jack input. This allows you to stream and control your music remotely from a smartphone or tablet for example. On the output side, the card is equipped with screw terminals for the speakers. A volume knob is also present for easy and convenient sound level adjustment.
Product typeAmplifier module
InputsBluetooth 5.0
1* USB-A (USB-Host)
1* Jack 3.5mm
OutputsSpeaker output on screw terminals
Amplification chipInfineon MERUS MA12070
Output power2*35W @ 4Ω, 19V, 1% THD+N
THD+N0.003%
SNR110dB
Frequency response18Hz-25kHz
Supply voltage15-19VDC via Jack DC 5.5/2.5mm
Dimensions80*52mm
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)35.0
This small Class D amplifier module uses an Infineon MERUS™ MA12070 amplifier chip allowing it to develop a power of 2*35W under...
