By buying this product you get 42 loyalty points
Plate NCore Amplifier 2x125W DSP ADAU1450 DAC AK4454 192kHz
The Hypex FusionAMP FA122 plate amplifier can be used to design an active subwoofer or two-way speaker. It is based on two NCore modules capable of developing 2x125W RMS which can also be bridged to form a 1x250W amplifier. This high power allows it to accompany speakers that need a large energy reserve to reveal their potential.
On the connector side, the FA122 offers a balanced analog input and output in XLR 3-pin format and an unbalanced RCA Stereo output. The XLR output is directly connected to the XLR input and therefore allows you to create a chain with several FusionAMPs, the maximum number of modules being limited by the capabilities of your source. Similarly, the amplifier has an AES input and output, the output also being directly connected to the AES input. In addition, there is a SPDIF Coaxial input/output and a Toslink Optical input.
This FusionAMP FA122 integrates a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. The latter offers many possibilities to adapt your amplifier to your needs, such as creating custom filters.
The front of the amplifier displays a series of 4 status LEDs. The first one is used to warn of a malfunction or when a limit is reached, in order not to damage the equipment.
The next 3 LEDs, green, simply display the selected custom profile and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will flash slowly.
| 1 | Balanced analog input / output |
| 2 | Singled-Ended analog input |
| 3 | Mini-USB connector for configuration |
| 4 | Status LED |
| 5 | AES input / output |
| 6 | SPDIF Coaxial input / output |
| 7 | Optical Toslink output |
Note: In order to protect your speakers, the DSP does not have a filter pre-configured by the manufacturer. A filter must therefore be configured and injected using Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
| Specifications | |
| Product type | Plate amplifier |
| Power | 2x125W |
| Inputs | 1x Balanced 3 poles XLR 1x Single-Ended Stereo RCA 1x AES 1x SPDIF Coaxial |
| Outputs | 1x Balanced 3 poles XLR (direct output) 1x AES 1x SPDIF Coaxial 1x Optical Toslink |
| DSP | ADAU1450 |
| DAC | AK4454 |
| ADC | AK5554 |
| SRC | SRC4382 - Max sampling rate : 192kHz |
| Frequency response | 20Hz - 20kHz |
| SNR AD/DA | -109dB |
| SNR DA | -111dB |
| THD+N AD/DA | -100dB @ -1dBFS |
| THD+N DA | -102.5dB @ -1dBFS |
| General | |
| Dimensions | 315 x 120 x 55mm |
| Weight | 815g |
| Color | Black |
| A | 315mm |
| B | 120mm |
| C | 55mm |
| D | 293mm |
| E | 96mm |
| Input | RCA |
| Input | SPDIF |
| Input | XLR |
| Output | XLR |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Hypex Ncore |
| Power (W) | 125.0 |
