Hypex FusionAMP FA253
3.0 / 5
By buying this product you get 64 loyalty points
Reference : 13532
649,00 €tax incl.
540,83 € tax excl.
Plate NCore Amplifier 2x250W + 1x100W DSP ADAU1452 DAC AK4454 192kHz
Hypex FusionAMP FA253 Amplificateur NCore Plaque 2x250W + 100W DSP ADAU1452 DCC AK4454 192kHz
The Hypex FusionAMP FA253 plate amplifier can be used to design a two- or three-way active speaker. It is based on two NCore modules capable of developing 2x250W RMS which can also be bridged to form a 1x500W amplifier. There is also a third NCore amplifier delivering 1x100W RMS for a tweeter. This high power allows it to accompany speakers that need a large energy reserve to reveal their potential.
Hypex FusionAMP FA253: Connectivity & other features
On the connector side, the FA253 offers a balanced analog input and output in XLR 3-pin format and an unbalanced RCA Stereo input. The XLR output is directly connected to the XLR input and therefore allows you to create a chain with several FusionAMPs, the maximum number of modules being limited by the capabilities of your source. Similarly, the amplifier has an AES input and output, the output also being directly connected to the AES input. In addition, there is a SPDIF Coaxial input/output and a Toslink Optical input.
This FusionAMP FA253 includes a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. The latter offers many possibilities to adapt your amplifier to your needs, such as creating custom filters.
The front of the amplifier displays a series of 4 status LEDs. The first one is used to warn of a malfunction or when a limit is reached, in order not to damage the equipment.
  • Fixed green : Amplifier power on
  • Blinking green : IR signal received
  • Green / red blinking : Clipping signal
  • Slow green blinking : Mute mode (output not workink)
  • Fixed red : DC Error/ Fatal error, amplifier shutdown
  • Blinking one time per second : High temperature, limited output
  • blinking two time per second : Over temperature, output not working
The next 3 LEDs, green, simply display the selected custom profile and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will flash slowly.
1Balanced analog XLR input / output
2Single-ended RCA Input
3Mini-USB connector for configuration
4Status LED
5AES input / output
6SPDIF Coaxial input / output
7Optical Toslink output
Hypex FusionAMP FA253: Operating diagram
Note: In order to protect your speakers, the DSP does not have a filter pre-configured by the manufacturer. A filter must therefore be configured and injected using Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
Product typePlate amplifier
Power2x250W + 100W
Inputs1x Balanced 3 poles XLR
1x Single-ended Stereo RCA
1x AES
1x SPDIF Coaxial
Outputs1x Balanced 3 poles XLR (direct output)
1x AES
1x SPDIF Coaxial
1x Optical Toslink
DSPADAU1452
DACAK4454
ADCAK5554
SRCSRC4382 - Max sampling rate : 192kHz
SNR AD/DA-109dB
SNR DA-111dB
THD+N AD/DA-100dB @ -1dBFS
THD+N DA-102.5dB @ -1dBFS
Dimensions360 x 135mm
Weight1145g
Dimensions
A360mm
B135mm
C55mm
D336mm
E111mm
InputXLR
OutputCoaxial SPDIF
OutputOptical Toslink
Channel2 (Stereo)
Channel2.1
Amplifier chipHypex Ncore
Power (W)250.0
Beaucoup de potentiel, mais pas mature
J'ai déjà réalisé plusieurs projets d'enceintes en tri amplification avec différentes solutions. La marque Hypex est sérieuse, et les produits sont bons. j'ai testé complètement ce module. Du point de vue hardware, il répond aux spécifications. Très bonnes.Par contre, coté logiciel et dsp, la solution n'est pas du tout mature . Beaucoup de bugs, pas du tout pratique à utiliser contrairement aux minidsp. Vraiment dommage! Hypex doit regarder la concurrence et faire évoluer son logiciel de qualité prototype ! Je vous souhaite bien du plaisir...
Michel
This review has been posted for HYPEX FUSIONAMP FA253 Plate NCore Amplifier 2x250W + 1x100W DSP ADAU1452 DAC AK4454 192kHz
