By buying this product you get 78 loyalty points
NCore Amplifier Module BTL 2x500W + 100W 4 Ohm
The Hypex FusionAmp FA503 can be an excellent foundation for designing a powerful 2-way or 3-way speaker. It is indeed capable of delivering 2x500W RMS power at 4Ω using a pair of NCore amplifiers. It can also be bridged (BTL mode) to obtain a powerful 1000W RMS amplifier. An additional channel of 100W RMS allows to power a tweeter.
On the connection side, there is a balanced XLR input, an unbalanced RCA input, an AES input, a Coaxial SPDIF input and a Toslink Optical input on the front panel. Pass-Through outputs are available for XLR, AES and Coaxial. A Mini USB configuration interface is also present.
The FA503 also includes 15 biquad filters per amplifier, 3 predefined filter profiles, a source select button, a signal detection and auto power off function, and a complete protection system.
| Specifications | |
| Product type | Amplifier module |
| Power | 2x500W + 1x 100W RMS @ 4Ω 2x 350W + 1x 100W RMS @ 8Ω |
| Inputs | 1x Balanced XLR 1x Single-ended RCA 1x AES 1x SPDIF Coaxial 1x Optical Toslink 1x Mini USB configuration port |
| Pass-Through outputs | 1x Balanced XLR 1x AES 1x SPDIF Coaxial |
| BTL | 1x 1000W |
| Input selection | |
| Auto shutdown | |
| Signal detection | |
| General | |
| Voltage supply | 100 - 240VAC ±10% |
| Dimensions | 420 x 150 x 90mm |
| Weight | 2880g |
| Package | 1x Hypex FusionAmp FA503 Speaker connection cables |
| Input | XLR |
| Input | Optical |
| Input | RCA |
| Input | SPDIF |
| Input | AES/EBU |
| Output | XLR |
| Output | ACSS |
| Output | Coaxial SPDIF |
| Channel | 2.1 |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Hypex Ncore |
| Power (W) | 500.0 |
| Power (W) | 1000.0 |
