By buying this product you get 22 loyalty points
Class D Stereo / Mono Amplifier Module 2x215W / 1x450W 4Ω
The ICEpower 125ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of 2x125W under 4Ω or 1x450W under 4Ω, while ensuring a precise and detailed sound reproduction. It also embeds its own power supply stage for a minimum size, a great ease of integration and above all peak performance. Its auxiliary power supply output allowing to supply external modules as well as the elimination of any heatsink or EMI shielding favors even more this ease of implementation of the module. It also benefits from a series of protections against short-circuits, overloads and overheating.
Product type | Amplifier module |
Amplification type | Class D |
Channels | Stereo (2) / Mono (1) |
Input | 1* Analog input on JST 8 pins connector |
Output | Speaker output on JST 4 pins connector |
Output power @ SE, THD+N 1%, 20Hz-20kHz | 125W @ 4Ω 150W @ 8Ω |
Output power @ BTL, THD+N 1%, 20Hz-20kHz | 450W @ 4Ω |
Output power @ SE, THD+N 10%, 20Hz-20kHz | 150W @ 4Ω |
Output power @ BTL, THD+N 10%, 20Hz-20kHz | 550W @ 4Ω |
Minimum load impedance | 3Ω |
Maximum total amp + PSU efficiency | 86% |
Peak output current | 20A |
Dynamic range | SE : 117dB BTL : 121dB |
Noise floor @A-Weighted | SE : 30µV BTL : 36µV |
THD+N (1W/1kHz) | 0.003% |
Gain | 24.3dB |
Supply voltage | 85-264VAC (supply voltage switchable via jumper) |
Dimensions | 160*80*32.6mm |
Package | 1* ICEpower 125ASX2 Wiring cables |
Input | PCB Connector |
Output | PCB Connector |
Channel | 1 (Mono) |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 125.0 |
Power (W) | 450.0 |
