MA-TA04 TA3020 V3.1 Amplifier Class D 2x300W 4Ω
The Connex MA-TA04 TA3020 3.1 is a Class T stereo amplifier module, based on a Tripath TA3020 amplifier chip. This one is thus able to develop a considerable power of 2x300W under 4Ω with a high efficiency of 92%, and this in a compact format.
4.6 / 5
Reference : 6462
124,90 €tax incl.
104,08 € tax excl.
Shipping date: 07-04-2026.
MA-TA04 TA3020
Class T Amplifier Module 2x300W 4Ω
MA-TA04 TA3020 Module Amplificateur Class T 2x300W 4Ω
The Connex MA-TA04 TA3020 3.1 is a Class T stereo amplifier module, based on a Tripath TA3020 amplifier chip. This one is thus able to develop a considerable power of 2x300W under 4Ω with a high efficiency of 92%, and this in a compact format. The module can also operate in bridge mode, to develop a power of 960W under 4Ω. The circuit also benefits from an overload and short circuit protection system.
It is imperative that the AUX connection be made between the amplifier and the power supply.
If a Connex power supply recommended by the manufacturer is not used to power the module, then the module will require, in addition to the +/-VCC power supply, additional +AUX, -AUX and Vbias power supplies to be distributed on the AuxSupply connector.
Product typeAmplifier module
Amplifier typeClass T
Amplification chipTripath TA3020
Output power2x 300W @ 4Ω, 0.1% THD+N, ±55V
2x 160W @ 8Ω, 0.1% THD+N, ±55V
Bridge mode960W @ 4Ω
540W @ 8Ω
THD+N0.02% @ 100W, 4Ω
Efficiency92%
Supply voltageFrom +/-45V 5A to +/-55V 7.5A
Dimensions100 x 100 x 40mm
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTA3020
Power (W)300.0
5 reviews
modification
très bon si l'on modifie les selfs en sorties
les transistors et deux ou trois résistance !
par contre petite erreur ! ce n'est pas de la classe D mais de la T ....
This review has been posted for MA-TA04 TA3020 V3.1 Amplifier Class D 2x300W 4Ω
Ce module gagne énormément en blindant alim et ampli par capot en alu (ne pas oublier les évents sur chaque capot), et blinder, évidemment, les connections du signal d'entrée:
Disparition notable du souffle(inaudible en sortie des HP) et des perturbations EMI.
Module à associer avec la SMPS 500 Connex recommandée par Audiophonics.
J'avais essayé avec une alim standard sans softstart en jouant uniquement sur la fonction mute : les HP encaissaient un ploc assourdissant et inquiétant!
Avec la SMPS, le module donne tout son potentiel (50h de "rodage" mini), il est proche des Nuforce Ref9SEV2, avec l'émission de EMI bien moins envahissante : pas de perturbation de la radio!
ATTENTION ! ce module n'intègre pas de relais de commutation temporisé des hauts-parleurs,
Modules de protections qu'il faut impérativement prévoir en plus de l'alim SMPS500R !
Sinon, les Haut-parleurs en prennent plein la tête à la mise sous tension et à la mise hors tension.
( Pas d'avis sur la qualité du son pour l'instant car dans l'état actuel des choses, je n'ai pas osé brancher mes HPs. Essais uniquement sur des Sub 500W qui ne craignent pas grand chose )
Cet ampli est de très bonne qualité, avec un son excellent sur mes Cabasse. Il faut lui mettre un bon convertisseur en amont pour qu'il puisse s'exprimer et ravir vaux oreilles.
The Connex MA-TA04 TA3020 3.1 is a Class T stereo amplifier module, based on a Tripath TA3020 amplifier chip. This one is thus able to develop a...
