2x120W 8Ω
This amplifier is composed of two mono modules, each integrating 2 LM3886 amplification chips in Class AB, coupled to 2 AOP NE5532D mounted on DIP8, for a total of 4 amplification chips. With these components, the amplifier is capable of delivering 2x120W under 8Ω to efficiently power your audio system.
The dual mono design (one channel per module) allows to separate the power supplies to obtain a cleaner current, to limit crosstalk and to obtain a much more aerated sound image.
To ensure true separation, each channel uses a high-gain Op Amp. This architecture results in deeper bass and dynamic high frequencies.
Each module integrates a loudspeaker protection circuit using an Omron relay. Your high-end speakers have nothing to worry about with this amplifier.
In addition, to ensure high signal accuracy and noise reduction, these modules are based on a symmetrical architecture.
Each module integrates high quality components, contributing to the sound quality of the product. For example, there are ELNA, Nover capacitors or an Omron relay.
The modules are mono bridge modules. This means that you need to use one stereo potentiometer (10K to 50K) per channel, or one 4-channel potentiometer. To do this, you need to remove the jumpers on the back of the board, using a soldering iron.
Product feeding: To properly supply this product we recommend that you carry out this Toroidal transformer 160VA 2x24V + 2x15V Standard profile.
Amplification chip | LM3886 |
Power | 2x120W 8Ω |
Power supply | 24V-0-24V + 15V-0-15V |
Inputs | XLR RCA |
Outputs | Speaker terminal |
AOP | 2x NE5532D |
Dimensions (1 module) | 170 x 83 x 40mm |
Weight | 280g each module |
Input | XLR |
Input | RCA |
Output | Speaker terminal |
Channel | 1 (Mono) |
Class | Class A / AB |
Amplifier chip | LM3886 |
Power (W) | 120.0 |
