WONDOM AA-AB31211 Amplifier board TPA3118 Class D Mono 60 Watts 4 Ohms
4.0 / 5
Reference : 10331
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 28-05-2025.
This compact Mono TPA3118 Class D amplifier module is a formidable efficiency: it delivers 60W at 4 Ohms and does not require the addition of a heat sink thanks to the design of its PCB.
Ideal for all types of DIY projects, it will integrate easily into your audio systems thanks to its simplified implementation.
Due to its range of power it is very convenient and can easily run on batteries. It has a DC jack input 5.5 / 2.5mm.
Characteristics :
  • TPA3118 amplifier
  • Class D architecture
  • PBTL Topology
  • Excellent audio quality
  • Line Level Input (2VRMS) Solder Pin or RCA
  • Overcurrent protection and overheating
  • Hp protection ("plocs")
  • Power: 45 @ 4 ohm (<0.1% THD + N), 60W @ 4 ohm (<10% THD + N)
  • Input impedance: 30K ohm
  • Input sensitivity: 1.18Vrms
  • Frequency response: 20Hz - 20kHz to +/- 3dB
  • Operating temperature: 0 to 50 ° C
  • Yield: 91% at 21V
  • Power supply: 9 to 24VDC (21V recommended) / DC jack 5.5 / 2.5mm
  • Dimensions: 100x68x15mm
  • Weight: 52g
[Img-13541-left-thickbox_default]
[Img-13542-left-thickbox_default]
[Img-13543-left-thickbox_default]
InputSolder pad
OutputScrew terminals
Channel1 (Mono)
Amplifier chipTPA3118
Power (W)60.0
un bon petit module
Je cherchais à amplifier mes enceintes (cabasse mc40 java) pour me libérer de l'emprise des câbles. Ce module est correct mais l'amplification des basses fréquences nécessite un appel de courant que les alims toute prêtes ne peuvent lui donner. Néanmoins un module assez efficace.
This review has been posted for WONDOM AA-AB31211 Amplifier board TPA3118 Class D Mono 60 Watts 4 Ohms
