WONDOM JAB4 AA-JA33285 Amplifier Board 4 Ways TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm
The JAB4 is a 4-channel amplifier module featuring Bluetooth 5.0 and an ADAU1701 DSP for an all-in-one audio solution. Based on a TPA3118 amplifier chip, the JAB4 can deliver 30W per channel at 8Ω. Thanks to its DSP, it supports programming via the SigmaStudio PC software.
Reference : 15454
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 07-04-2026.
Wondom JAB4
Amplifier Board 4 Ways Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm
Wondom JAB4 Module Amplificateur 4 Voies TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm
The JAB4 is a 4-channel amplifier module featuring Bluetooth 5.0 and an ADAU1701 DSP for an all-in-one audio solution. Based on a TPA3118 amplifier chip, the JAB4 can deliver 30W per channel at 8Ω. Thanks to its DSP, it supports programming via the SigmaStudio PC software after connecting to a Wondom ICP5 module (sold separately). This software allows access to functions such as volume, gain, frequency adjustment or the use of equalizers.
In addition to its 4.0 operation, the JAB4 can be used in 2.1 mode at 2x30W + 1x60W or in 2.0 mode at 2x60W. The speaker output is done on Molex connectors. A connector also allows to recover the audio signal in I2S format. The input is done in Bluetooth or on a single-ended line input. The Bluetooth of this module supports the high definition codecs aptX, aptX HD and aptX LL. A port allows the connection of an external antenna (sold separately) to increase the distance and stability of the transmission.
There are also four connectors on the JAB4 to install potentiometers to easily control the gain level or the tone.
The JAB4 can be powered by a conventional power supply or by a battery module (sold separately), which is convenient for building a compact and portable system. In addition, the JAB4 is able to detect the input signal to reduce the power consumption of the module. If no signal is sent to the JAB4 for 5 minutes, it will go into standby mode. When a signal is detected again, the module will automatically and instantly turn on.
Product typeAmplifier module
Number of channels4.0
2.1
2.0
Output power4x 30W
2x 30W + 1x 60W
2x60W
InputsBluetooth 5.0
1x Single-ended line input
OutputsSpeaker output (Molex)
I2S
Amplification chipTPA3118
DSP chipADAU1701
PBTL mode support
Dimensions91 x 68mm
Measurements
ParameterConditionsMin.Typ.Max.
Number of channels--4-
Minimum load impedance--4Ω-
Efficiency4x30W @ 8Ω, 1kHz-87%-
Nominal power requirement@ 24V, 1kHz-140W-
Supply voltage@ 1kHz, 8Ω10V24V26V
Switching frequencySD Floating @ 24V-400kHz-
Consumption1/4 of max power @ 8Ω, 24V, 1kHz-31W-
Amplifier gain@ 8Ω, 20Hz-20kHz-26dB-
DSP gainSE1 (Single Amp) @ 8Ω, 1kHz-60dB-0dB
SE2 (Line output) @ 8Ω, 1kHz-60dB-6.5dB
Input sensitivity2x30W @ 8Ω, 1kHz, 26dB-770mV-
Filter gainButterworth, Q=0.707-4dB-
Cutout frequencyHFP0.25kHz-2kHz
LFP-20kHz-
SNR2x30W @ 8Ω, THD+N=1%, 26dB, A-Weighting-97dB-
THD+N10W @ 8Ω, 1kHz, 26dB-0.06%-
Input impedance--10kΩ-
Supported sampling rates--48kHz-
Output noise levelA-Weighitng, input connected to GND, 26dB-153µV-
DC offset--10mV-
Crosstalk separation20Hz-20kHz, Gain=26dB--60dB-
Wondom JAB4 Module Amplificateur 4 Voies TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm Wondom JAB4 Module Amplificateur 4 Voies TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm Wondom JAB4 Module Amplificateur 4 Voies TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm Wondom JAB4 Module Amplificateur 4 Voies TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm
InputPCB Connector
OutputI2S
OutputMolex
Channel4
Amplifier chipTPA3118
Power (W)30.0
Très bon produit
Utilisé sur un projet 2.1 avec caisson de basse. Il est possible de bridger deux sortit pour le caisson, et d'utiliser deux sortie en stéréo pour les médium aigue. Un petit programme avec SigmaStudio pour le crossover. Et voilà!
Utilisé aussi pour faire de l'amplification active avec filtrage sur des enceintes deux voie à titre expérimental. Très prometteur dans cette configuration.
This review has been posted for WONDOM JAB4 AA-JA33285 Amplifier Board 4 Ways TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm
The JAB4 is a 4-channel amplifier module featuring Bluetooth 5.0 and an ADAU1701 DSP for an all-in-one audio solution. Based on a TPA3118 amplifier...
