AUDIOPHONICS TRIPATH TA2022 DIY Stereo Amplifier Kit Silver 60W 8Ohm
AUDIOPHONICS TRIPATH TA2022. Kit DIY Amplificateur Stéréo Silver
4.8 / 5
Reference : 4677
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
This kit contains all the elements needed to assemble a digital stereo power amplifier based on the high performance circuitTRIPATH TA2022.
This amp needs a preamp to operate as it does not have volume control.
The housing is completely drilled to incorporate the kit elements as easily as possible.No drilling is required.
This realization requires very few tools to be able to be carried out.
The assembly is within reach of everyone and is a royal way to learn the joys of the DIY at a lower cost, with the ultimate achievement of a quality device, and the satisfaction of having made yourself one of the components of its Audio system.
Warning, this amplifier may be sensitive to radio interference from FM radios and tuners.
Available with front black on request in field comment
https://www.audiophonics.fr/images2/4677/4677_KIT_COMPLET_AUDIOPHONICS_TA22_7.jpg
Designed on AUDIOPHONICS specification, this assembly is characterized by its musicality of high flight and its impressive power with regard to its compactness.
The chipTA2022integrated, it is possible to achieve 2 x 90 Watts under 4Ω with a level of harmonic distortion extremely well controlled since not exceeding 0,1%.
In order to exploit the possibilities of this circuit prodigy, we have chosen to integrate components of higher quality, such 12 ELNA capacitorsof each one1200uF / 63V, cleverly allied to MKP, as well as a generously sized toroidal transformer.
Features:/ Strong>
  • Housing Thick aluminum with front 10mm Silver
  • Commissioning viaON / OFF button illuminated with a Blue Halo
  • Signal input on RCA Plated Gold Plated Plugs 24k
  • Outings onHP High Quality Gold Plated 24k Terminals and accepting thes heavy-section cables, as well as forks and banana plugs
  • IEC anti-interference power connector with built-in EMI filter
  • Requires a 150VA transformer - 2 x 24V (Power Stage - Chipset TA2022) + 9V (Driver Stage) + 12V (Lighting ON / OFF button)
  • Capacitors Panasonic FC 12x1200μF & MKP
  • Offset Setting Possible
Specifications:
  • Output Power per Channel: 60W / 8Ω (0.1% THD + N)
    90W / 4Ω (0.1% THD + N) ²
  • Total Harmonic Distortion Rate: 0.015% at 45W 8Ω
    0.015% to 70W 4Ω
  • Intermodulation Distortion Rate (SMPTE): 0.10% to 25W 4Ω
  • Dynamic Range: 102dB
  • Yield: 92% to 88W / 8Ω
    87% at 125W / 4Ω
  • Power Supply: Toric Transformer 160VA 2 x 20V
  • Dimensions: 230 x 280 x 80mm (L x W x H)
  • Weight: 4.450g
Attention : The black facade comes with a 16 mm Ø hole for the following power button: Power button Ta2022 plug 5209
Warning: The Silver front is delivered with a 19 mm Ø hole for the following power button: Power button Ta2022 button 8922
Composition of the Kit:
[Img-17845-left-thickbox_default]
[Img-17967-left-thickbox_default]
[Img-17797-left-thickbox_default]
[Img-17798-left-thickbox_default]
MaterialMetal
5 reviews
Ça y est, j'ai changé de siècle (en audio) en passant de l'amplification de puissance analogique à numérique !
Prudent, les ampli numérique correct étant un peu cher (sans avoir écouté préalablement), je me suis aventuré sur un KIT pré-monté, sur lequel il restait l'assemblage à réaliser : AUDIOPHONICS TRIPATH TA2022 : 199,00 €TCC … que l'on appellera (B) pour la suite du mail
Très bonne qualité de l'électronique et des composants. Bien qu'habitué au fer à soudé, le montage a été un peu long car j'ai dû ajuster un peu les usinages en raison d'une épaisseur de paroi plus importante que celle de la conception.
Condition de la première écoute comparative :
- J'ai pris des enceintes 2 voies (17 cm carbone, tweeter dôme) assez "normale", impédance 4 Ω
- En comparatif simultané un ampli de monitoring 2x100W/4Ω : ALESIS RA100 que l'on appellera (A)
- Envoi de la source audio CD sur les 2 amplis et choix de l'ampli à l'écoute par un sélecteur Passif au niveau HP (switch)
- Source CD (pas de signal type MP3)
- CD :
- Grace Jones / Hurricane
- Herbie Hancock / DIS IS DA DRUM
Ressenti comparatif à volume égal
Stéréo :
• (ALESIS RA100) : tendance floue
• (TRIPATH TA2022) : très précise et pas agressive
Dynamique :
• (ALESIS RA100) : tendance molle et un peu agressive sur certain passage
• (TRIPATH TA2022) : très nette, "réactive", sans inertie, très belle tenue des graves
Graves :
• (ALESIS RA100) : un peu ballonné, tendance à en rajouter
• (TRIPATH TA2022) : pas de "faux" graves si absent du disque, mais très propre si présent sur le CD. Ne polluent pas la stéréo (elle n'est pas affectée par la présence de graves assez importants) : [ Herbie Hancock - DIS IS DA DRUM ]
Voix :
• (ALESIS RA100) : un peu "médium" (légèrement colorée comparativement)
• (TRIPATH TA2022) : très naturelle, très nette
Avis global :
Sur des enceintes "moyennes" (en taille et en qualité), il y a un gap de 300% entre les 2 amplis. Cette amplificateur numérique apporte un vrai gain qualitatif à l'écoute, très grande précision mais sans agressivité, avec une stéréo très large et précise.
Prochaine étape : comparer avec mon "gros système" 3 voies, par rapport à l'ampli Audiophile MARANTZ 2 x 100W !
Pour un petite taille (a peu près une feuille A4), on a un son remarquable, grâce au numérique, à la technologie TRIPATH et la qualité de réalisation du kit.
This review has been posted for AUDIOPHONICS TRIPATH TA2022 DIY Stereo Amplifier Kit Silver 60W 8Ohm
J'ai acheté ce kit en août 2011, et après de nombreux essais décevants, j'ai enfin trouvé une configuration que je trouve aujourd'hui exceptionnelle et dont j'ai du mal à changer...
Ma première remarque est pour la finition du produit : Excellente, mais j'enlève un point à la note générale pour le prix. Je trouve dommage de ne proposer que des coffrets chers. Tout le monde n'a pas les compétences ou le matériel nécessaire pour usiner un coffret et j’achèterais de nombreux autres kits si un coffret de moindre coût était proposé en option. Même si je n'ignore pas qu'un bon coffret est important, mon Ampli Marantz (5 étoiles au Whathifi) m'a coûté 300€ neuf...
Écoutant principalement de la musique dématérialisée (EAC/FLAC/FOOBAR/ASIO) au travers de 2 DACS, un NOS et un Dacmagic, je pensais attaquer l'ampli en direct. J'utilise en général le 1/4 de la puissance de mon intégré Marantz annoncé à 2*45W en 8Ohm, mais là, déception, le rendement n'est pas au rendez-vous... Bof...
La dernière version du buffer avec résistances Vishay et gain paramétrable a ajouté le gain qui me manquait. Le module est enfin de très bonne qualité, et un gain de x10 avant un préampli passif avec potars à résistances donne un résultat détaillé et une scène que je trouve géniale! J'avais 2 aop LM4562NA que j'ai mis à la place des opa2134 déjà très bons =_ pourquoi pas un potar sur le buffer ? parce que mon préamp RIAA vient lui aussi sur ce préamp passif pour mon écoute vinyle.
J'attends avec impatience que d'autres kits complets soient proposés (avec des boitiers pas trop chers...) et notamment une version du contrôleur de volume 4 entrées qui viendrait compléter à merveille cet ampli TA2022.
J'ai passé quelques commandes chez Audiophonics dont j'ai également testé le SAV et je trouve que tout va de mieux en mieux - seuls les frais de port m’empêchent de passer de petites commandes... Et c'est quand même beaucoup plus agréable d'acheter du matériel de qualité près de chez vous qu'à Hong-Kong!
Bonjours à tous ,
Après l'achat de deux TA 2022 pour bi-amplifier mes ELIPSON FUTURA et quelques heures d'écoutes plus tard , je puis vous dire que tous les superlatifs pour encenser ces amplis ne manquent pas : un aigu chirurgical , un médium bien détouré et précis , un grave bien charpenté et rapide ...
Du coup je vais équiper tout mon système avec ces amplis .
Je tiens à préciser que mon matériel et d'abord HIFI et que je migre vers le Home cinéma avec cette même philosophie .
SUONA SUONA !!!!!!!! RIPRODUZIONE DELLA SCENA CREDIBILE, SPARISCONO GLI ALTOPARLANTI ( testato con varie coppie di diffusori blasonati) Abbinato ad un pre a valvole ....molto molto musicale.....soprattutto considerando la spesa !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! CONSIGLIATISSIMO .
kit d une très bonne qualitée , montage assez simple ( environ 2 heures )
je doit dire que j ai été agreablement surpris par la clartée du message sonore : aigu fin et cristallins , medium clairs et précis , bas du spectre présent mais pas trop
en bref ce kit rivalise avec les produits haut de gamme , avec les amplis du marché de haut niveau
a recomander a ceux qui aprécie la vrai hifi
puissance confortable
separation stéréo impressionnante
le MUST a ce prix
couplé a deux jean marie reynaud il fait le bonheur de mes oreilles
a recomander absolument a ceux qui veulent fabriquer leur amplis eux mème avec un budjet moindre
une chose a dire vive les modules class t
merci aussi a audiophonics pour leur sérieux et leur rapidité de livraison
