AUDIOPHONICS BT60DSP Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm
The BT60DSP is a revised and corrected version of the excellent BT60W amplifier, with elements of DSP processor and without volume control.
Reference : 14559
34,90 €tax incl.
29,08 € tax excl.
    This product has been replaced by the new version, the BT60W PRO Amplifier MA12070.
    Audiophonics BT60DSP
    Bluetooth 5.0 Amplifier 2x50W
    Audiophonics BT60W V2
    Audiophonics presents an alternative version of the very popular BT60V2 amplifier. It gives up its volume control and instead integrates a simple, efficient and preconfigured DSP processor. This version supports Bluetooth EDR (enhanced data rate) to take advantage from a more stable and less energy-consuming data flow when used as a bluetooth wireless receiver.
    It is designed to work as a bluetooth amplifier and can also work with any audio source with volume control such as a smartphone through its jack 3.5mm input.
    Small but powerful
    Now equipped with two 50W TPA3116D2 amplifier modules, the BT60DSP will offer you a significant boost of power, ideal for use with a computer, tablet or smartphone as input.
    Ergonomics first and foremost!
    To adapt to your needs in terms of connections, the BT60DSP offers a jack 3.5mm input.
    You do not want to be constrained by the use of cables and want to stream your music from your sofa? It comes with a Bluetooth 5.0 controller!
    As for the audio output, a terminal block allows you to connect the amplifier to your speakers. Finally, the power plug is now placed on the back, much more convenient for wiring.
    Designed around a chassis made of black anodized aluminum and white plastic, it is both extremely compact but also very elegant. It can be easily integrated into an audio system or on your desktop.
    Connections: Inputs
    3.5mm Jackx1
    Bluetooth 5.0Yes
    Terminal Blocks-
    Amplifier Modules2x TPA3116D2
    Power2x50W (4Ω)
    Bluetooth range15m
    SwitchOn / Off
    Power Supply12V 5A via Jack DC 5.5 / 2.5mm (included) - Accepts a voltage from 9 to 24V
    Miscellaneous
    Chassis materialBlack anodized aluminum and white plastic
    Dimensions78 x 70 x 23mm
    Weight118g
    Package
    3.5mm Male to RCA Stereo Male to Male Cable1x
    3.5mm Male to 3.5mm Jack Cablex1
    Power supply adapter 12V 5Ax1
    Noticex1
    InputJack 3.5mm
    OutputSpeaker terminal
    Channel2 (Stereo)
    Amplifier chipTPA3116D2
    Power (W)50.0
    2 reviews
    Bonne solution enceinte connectée
    Bonne qualité de son. En achetant des enceintes d'occasion, ça remplace avantageusement une enceinte connectée pour éccouter de la musique avec un smartphone, une tablette ou un PC.
    This review has been posted for AUDIOPHONICS BT60DSP Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm
    Bluffant
    Pour amplifier une paire de QA3010 comme système Hifi de bureau. Il est connecté à un convertisseur USB Fostex équipé d'un contrôleur de volume.
    Extra vu le budget.
