By buying this product you get 64 loyalty points
These ATH-WP900 headphones from Audio-Technica are closed-back dynamic circum-aural audio headphones featuring two Ø53mm transducers. Its curly maple shells, made by Japanese guitar maker Fujigen, guarantee clear, natural sound quality and high-end aesthetics. These headphones feature a very wide frequency response thanks to their structure and a power handling level of 1000mW. Its 38 Ohm impedance and connectivity make it compatible with most Hi-Fi equipment.
The exclusive Ø53mm transducers feature a powerful magnetic circuit, amorphous carbon (DLC, Diamond-like carbon) coating and overhanging circuit boards for exceptional full-band frequency reproduction. To improve air circulation between the front and rear of the diaphragm, Audio-Technica has incorporated an inclined baffle to accentuate midrange and bass.
The ATH-WP900 high-fidelity headset uses A2DC (Audio Designed Detachable Coaxial) connectors. This solution has been developed to offer a perfect balance between safety and ease of use, and to reduce unwanted connector rotation that can cause noise or signal interruptions.
The curly maple shell finish brings out the unique grain of each headset. In addition, the ear cushions and headband are covered in soft synthetic leather for long-lasting listening comfort. The headphones' swivel design makes them easy to carry.
The ATH-WP900 comes with two detachable 3m cables with A2DC connectors. One has a gold-plated 3.5mm jack connector, so the headphones can be used with a wide range of devices. The other has a symmetrical gold-plated 4.4mm jack connector, also for use with Hi-Fi equipment and high-quality sound reproduction.
Product type | High-fidelity audio headphones |
Transducer type | Dynamic closed |
Transducer diameter | Ø53mm |
Frequency response | 5Hz -50kHz |
Max. permissible input power | 1000mW |
Sensitivity | 100dB/mW |
Impedance | 38 Ohm |
Connectors | A2DC |
Net weight | 243g |
Package | 1x Audio-Technica ATH-WP900 headphones 1x A2DC to 3.5mm jack cable 1x A2DC to 4.4mm balanced jack cable 1x Carrying pouch |
Color | Wood |
Impedance (Ω) | 38 |
Efficiency / Sensitivity (dB) | 100.0 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 50000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | A2DC |
