AUNE SR7000 Headphones
Aune's SR7000 are closed-back circumaural headphones with Ø50mm MLD (Multi-Layer Distributed) dynamic drivers. Its design, combining a composite ceramic diaphragm and flexible suspension, enables it to offer a frequency response ranging from 5Hz to 45,000Hz. Furthermore, the SR7000 benefits from innovations such as the use of acoustic metamaterials in the rear cavity and the special positioning of the drivers, resulting in a very wide soundstage, with exemplary spatialisation and a timbre devoid of the resonance usually found in closed headphones.
By buying this product you get 63 loyalty points
Reference : 19861
639,00 €tax incl.
532,50 € tax excl.
Shipping date: 14-04-2026.
Aune SR7000 Closed-Back headphones Ø50mm 55Ω 106dB 5Hz-44.5kHz
AUNE SR7000 : Front view
Aune SR7000: Ø50mm dynamic driver
For its SR7000, Aune has developed a brand new Ø50mm dynamic driver. It features a W-shaped composite cone made of ceramic-reinforced polymer. This new driver is optimised using multilayer distribution compensation (MLD), enabling it to vibrate across the entire frequency band, with good extension at high frequencies. As a result, this new driver enables the SR7000 to offer a frequency response ranging from 5Hz to 44500Hz with extremely low linear distortion.
AUNE SR7000 : Ceramic diaphragm
Aune SR7000: Flexible suspension
The SR7000's ceramic and polymer composite cone is fitted with an independent flexible suspension that has been specially optimised for this model, ensuring that its movements are stable, even when it is moved widely. The airflow has also been designed to deliver deeper bass, worthy of high-end loudspeakers in a room with carefully considered acoustics.
AUNE SR7000 : Cutaway view of a driver
AUNE SR7000 : metamaterial
Aune SR7000: Acoustic metamaterial
When designing the SR7000 headphones, Aune not only innovated with a new driver, but also with the incorporation of an acoustic metamaterial. This type of material with a negative refractive index is used here for its ability to completely absorb certain frequency bands. Proprietary acoustic prisms called ‘Dragon Scale’ have been developed by Aune to be placed in the rear cavity of the headphones, providing a more natural, open sound by absorbing the resonances that would otherwise occur in closed headphones.
Aune SR7000: Tilted acoustic Matrix
The SR7000 also benefits from the "Tilted acoustic Matrix" solution. This is a design developed using computer simulations to position the driver at an angle that allows the sound emitted to penetrate directly into the ear canal, regardless of the shape of your head, with the headphones adapting to you thanks to the foams on the sides of the earcups. This tilted design results in a wider, more accurately spatialised soundstage, enabling the SR7000 to compete with headphones with an open design.
AUNE SR7000 : Tilted acoustic Matrix
AUNE SR7000 :Cutaway view of an earpiece
Aune SR7000: Genuine comfort
These circumaural headphones have a concentric circle adjustment system and a very light structure for comfort even during very long listening sessions. The foams are made from a breathable material with a slow acoustic rebound.
Aune SR7000: A headphone easy to drive
The SR7000's 55Ω impedance design offers an ideal balance between great sound quality and wide compatibility. When paired with a nomadic or sedentary headphone amplifier, these headphones can unfold their full capabilities and deliver sound reproduction of rare quality.
AUNE SR7000 : frequency response curve
Product typeCircumaural headphones
Headphone typeClosed-back
Driver typeDynamic with MLD technology
Frequency response5Hz-44.5kHz
Nominal impedance55Ω
Sensitivity106dB
Total harmonic distortion (THD)< 0.03%
Dimensions260 x 275 x 153mm
Weight390g
ColorGreen
Package1x Aune SR7000
1x AuNest storage bag
1x 1.5m OFC copper 3.5mm jack cable
1x 1.5m OCC copper 4.4mm jack cable
1x 3.5mm to 6.35mm jack adapter
ColorGreen
Impedance (Ω)5
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)5
Highest frequency (Hz)44500
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
Équilibré tout en restant fun
Comme indiqué dans le titre, je trouve le sr7000 absolument essentiel.
Un casque fermé avec une sensation de casque ouvert, une scène sonore ouverte contrairement a ce qu'on pourrait attendre d'un casque fermé, c'est génial.
Que sa soit pour la bureautique, gaming et surtout pour mes longues sessions d'écoute je le trouve jamais fatiguant, aucune fréquence n'est exagéré et très confortable.
Comme je l'ai dis, je le trouve indispensable. Sa neutralité ne tombe pas dans le son clinique dun casque dédié studio d'enregistrement, et superbe contrôle sur tout le registre, c'est délicieux.
Petite indication quand même, si vous aimé de grosse basse explosive et un peu exagéré, c'est pas ce casque qu'il vous faut sauf si vous utilisé un égalisateur.
This review has been posted for AUNE SR7000 Closed-Back Headphones Ø50mm 55Ω 106dB 5Hz-44.5kHz
Aune's SR7000 are closed-back circumaural headphones with Ø50mm MLD (Multi-Layer Distributed) dynamic drivers. Its design,...
