FiiO offers with the FT3 32 Ohms headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and very modern design. The frequency response is very wide thanks to its open design, which allows to obtain a very vast sound scene in listening. Its sound rendering is very detailed. Design-wise, it is very comfortable thanks to its ergonomic design pivoting on 3 axes.
The FT3 of FIIO embarks a large transducer of 60mm of diameter in each ear. This allows it to send a more natural sound and to extend its sound scene. This large transducer allows the FIIO FT3 to go for deeper bass and to support a high power output while keeping a low level of distortion thanks to a beryllium plated suspension edge. The diaphragm is made of DLC (Diamond Like Carbon) which makes it light and rigid at the same time.
In addition, the design uses powerful N52 neodymium magnets to maximize sound quality. They are positioned in an internal and external magnetic circuit in an asymmetrical and optimized way. As a result, the FT3 HiFi headphones are very responsive and dynamic.
The open design of the FIIO FT3 headphones delivers detailed audio with clear, precise and natural sound, all with a wide-open soundstage. The headphones' low impedance (32 ohms) and high sensitivity (102db) mean they can be combined with any HiFi source such as a headphone amplifier or audiophile DAP to exploit their full potential. Unlike the FT3 350 Ohms version, it can also be used directly with a smartphone.
The Fiio FT3 cable is 3m long and made of pure Japanese Furukawa single crystal copper with a diameter of 23AWG. It has four interchangeable connectors: two interchangeable plugs of Jack 3.5mm and Jack 4.4mm and two adapters Jack 3.5mm to Jack 6.35mm and Jack 4.4 mm to XLR-4 balanced.
Both robust and lightweight, the helmet's frame is made of an aluminum alloy. This makes it a fairly light product for its size with remarkable durability qualities. In terms of wearing comfort, its innovative three-axis swivel design gives it the ability to adapt to all types of body shapes and avoids sound leakage. Finally, the headset comes with two pairs of earpieces, one in suede and one in imitation leather, as well as a hard protective pouch.
Product type | Audio Headphone |
Headphone type | Open-Back Circumaural |
Speakers type | Dynamics (Beryllium plated gasket + DLC diaphragm) |
Speakers diameter | Ø60mm |
Frequency response | 7Hz-40kHZ |
Sensibility | 102 dB (1Vrms) @ 1 kHz |
Impedance | 32Ω |
Connectors | Cable with 3.5 mm interchangeable plug Cable with 4.4 mm interchangeable plug 3.5 mm female to 6.35 mm male adapter Adapter 4.4 mm female to XLR-4 male balanced |
Headset pressure | 4.0 N ± 0.3 N |
CAble | |
Lenght | 3m |
Material | Furukawa single crystal copper wire |
Headphone connectors | Double 3,5 mm |
Outer shell material | TPE |
Shield layer | PCOCC-A (26/0.12X2) |
Insulation layer | PFA |
Conductor | PCOCC-A (3/20/0,8X2AWG23) |
External diameter | 2.4 mm x 2 (parallel structure) |
Color | Black |
Weight | 391g |
Package | 1x Fiio FT3 headset 1x Cable with interchangeable 3.5 mm plug 1x 4.4 mm interchangeable plug 1x Adapter 3.5 mm female to 6.35 mm male 1x Adapter 4.4 mm female to XLR-4 male balanced 1x Storage case 1x Leatherette earpieces 1x Suede ear pads |
Color | Black |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 102.0 |
Lowest frequency (Hz) | 7 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | XLR 4-pin |
Cable termination | Jack 3.5mm |
Cable termination | Jack 6.35mm |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | Jack 3.5mm |
