HIFIMAN HE-R10D Headphones
The HIFIMAN HE-R10D are dynamic closed-back circumaural headphones featuring powerful 50mm drivers. These transducers are combined with finely machined wooden shells, which form an optimised acoustic cavity, allowing detailed sound reproduction and a surprisingly wide soundstage for a closed model. With an impedance of 60Ω and a sensitivity of 103dB, it's relatively easy to drive. To ensure maximum compatibility, three cables with 3.5mm TRS jack connectors and different terminations are supplied.
Reference : 20476
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 17-07-2025.
HIFIMAN HE-R10D Casque Audio Dynamique Fermé Circumaural 60 Ohm 103dB 15Hz-35kHz
Photo of HifiMan HE-R10D
The frequency response of the HifiMan HE-R10D
HIFIMAN HE-R10D: A Ø50mm diaphragm
The HE-R10D's diaphragm uses a technology consisting of nanoparticles applied to target areas of the diaphragm to optimize its properties for better performance. The brand also uses high-sensitivity magnets for greater dynamics across the entire frequency range from 15Hz to 35kHz.
The diaphragm of the HIFIMAN HE-R10D headphones
The wooden shell of the HIFIMAN HE-R10D
HIFIMAN HE-R10D: A CNC-machined wooden shell
The HE-R10D's CNC-machined wood shell is large enough to provide adequate breathing space for the headphones' powerful 50mm diaphragm. In addition, the selected wood has unique acoustic properties. This wood shell offers an acoustic cavity that helps suppress unwanted resonances while providing a wide soundstage despite the headphones' closed design. Overall sound reproduction is also more natural and clear.
HIFIMAN HE-R10D: Comfortable headphones
Ideal for long listening sessions thanks to its large earcups and adjustable headband, the HIFIMAN HE-R10D headphones adapt to a wide range of head shapes. The earcups and headband are padded for optimum wearing comfort and weight distribution.
Photo of Hifiman HE-R10D headphones
Product typeHeadphones
Headphone typeClosed-back circumaural
TransducerDynamic
Transducer diameterØ50mm
Impedance60 ohm
Sensitivity103dB
Frequency response15Hz-35kHz
Weight360g
ColorWood
Package1x HIFIMAN HE-R10D headphones
1x Cable jack 3.5mm TRS to termination jack 3.5mm (1.5m)
1x Jack 3.5mm to jack 6.35mm adapter
ColorWood
Impedance (Ω)60
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)15
Highest frequency (Hz)35000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Cable terminationXLR 4-pin
Headphone / Earphone connectorJack 3.5mm
HIFIMAN HE-R10D Closed Dynamic Circumaural Headphones 60 Ohm 103dB 15Hz-35kHz
The HIFIMAN HE-R10D are dynamic closed-back circumaural headphones featuring powerful 50mm drivers. These transducers are combined with finely...
