Le casque est volumineux mais son port est confortable ; on à tendance à l'oublier . Le son est détaillé et le rendu spatial séduisant et pas caricatural . Un bon compromis pour moins de 300 euros . Fait aussi bien que certains casques plus chers .
By buying this product you get 44 loyalty points
The Monolith M1060C headphones feature redesigned planar magnetic drivers capable of reproducing a detailed and accurate soundstage in a closed-back design. Low distortion and perfectly balanced sound make the M1060C a true ally for audiophiles and music lovers who want to enjoy a high level of sound reproduction.
Planar Magnetic drivers
The M1060C's magnetic planar drivers have been completely redesigned from those adopted by its predecessor, the M1060. Several improvements have been made, including a new balanced magnetic structure that allows the driver to be much more efficient in a closed cabinet. The result is a very low distortion, a greater linearity and a spectacular sound image.
Closed back design
With the M1060C, outside noise stays outside! Offering excellent audio isolation, the M1060C allows for undisturbed listening, just as those around you will not be disturbed by the sound of your headphones. An ideal headphone for listening sessions in noisy environments.
Comfort
The M1060C is designed to be comfortable even during long listening sessions. Its large, comfortable leatherette-covered earpads and padded headband prevent pain and fatigue.
Product type | Audio heaphones |
Style | Closed back |
Transducer type | Planar magnetic |
Magnetic structure asymmetry | Néodyme push-pull |
Magnet type | High grade N50 neodymium |
Drive size | Ø106mm |
Maximum power handling | 5W Max. |
Maximum SPL | > 120dB |
Frequency response | 10Hz - 50kHz |
THD | < 1% @ 1mW, 1kHz |
Impedance | 18Ω |
Efficiency | 90dB /1mW |
Optimal power requirement | 1W |
Weight | 483g |
Color | Black |
Color | Walnut |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 90.0 |
Lowest frequency (Hz) | 10 |
Highest frequency (Hz) | 50000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Cable termination | Jack 6.35mm |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
jérome M.
Delacour j.
Delacour j.
