MOONDROP VOID Dynamic Open-Back Headphone Ø50mm 64 Ohm 110dB 20Hz-20kHz
15%
Moondrop unveils Void, an open-back dynamic headphone that is as powerful as it is comfortable. Its careful design, using a speaker specially developed by the brand, allows the headphones to provide a musical, dynamic and accurate sound, for an optimal listening experience both at home and on the move.
Reduced price!
Reference : 17216
Limited time offer:
239,00 €tax incl.
-15%
203,15 €tax incl.
169,29 € tax excl.
Shipping date: 06-05-2025.
Moondrop Void
Dynamic Open-Back Headphone Ø50mm 64Ω 110dB 10Hz-80kHz
Moondrop Void Casque dynamique ouvert Ø50mm 64Ω 110dB 10Hz-80kHz
A dynamic speaker with incredible performance
The Void is equipped with 50mm diameter dynamic drivers, specifically developed by the brand, allowing the headphones to provide excellent sound performance. The rest of the components are then perfectly tuned and optimized around this driver. The magnetic circuit has been designed to provide high efficiency to allow the Void to reproduce your music with dynamism and precision. The diaphragm is accompanied by a soft suspension and a metalized dome, ensuring a nice extension in the high frequencies and a nice dynamic in the midrange and bass.
1Metal coated dome
2CCAW Voice coil
3High efficiency magnetic circuit
4Flexible damping suspension ring
5N52 Magnet
Product typeHeadphone
Headphone typeDynamique
Ouvert
Driver diameterØ50mm
Headphone connectorsJack 3.5mm
Frequency response10Hz - 80kHz
Effective frequency response20Hz - 20kHz (IEC60318-4, -3dB)
Impedance64Ω ±15% @ 1kHz
Sensitivity110dB/Vrms @ 1kHz
ColorWhite
Package1* Moondrop Void
1* Jack 3.5mm to Jack 6.35mm adapter
1* Jack 3.5mm cable
ColorWhite
Impedance (Ω)64
Efficiency / Sensitivity (dB)110
Lowest frequency (Hz)10
Highest frequency (Hz)80
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
Moondrop unveils Void, an open-back dynamic headphone that is as powerful as it is comfortable. Its careful design, using a speaker specially...
