DAYTON AUDIO H6512 Wave Guide High Frequencies 16.5 x 30.5cm
10%
This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures accurate reproduction and an open sound stage, allowing you to reveal the full potential of your tweeters.
Reduced price!
Reference : 14359
Limited time offer:
20,90 €tax incl.
-10%
18,81 €tax incl.
15,68 € tax excl.
Shipping date: 26-06-2025.
Grantie 5 ans
Dayton Audio H6512
Waveguide High Frequencies 16.5 x 30.5cm
Dayton Audio H07E Pavillon Wave Guide Hautes Fréquences Ø15.2cm
This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures accurate reproduction and an open sound stage, allowing you to reveal the full potential of your tweeters. The H6512 is molded from high quality plastic and its screw thread is the industry standard 1-3/8" x 18 TPI. Its shape provides 90° horizontal and 50° vertical coverage and offers an acoustic load up to 1000Hz.
Product typeWaveguide for high frequencies driver
Output diameter16.5 x 30.5cm
Screw thread format1-3/8" x 18 TPI
Acoustical loadDown to 1000Hz
Coverage patternHorizontal : 90°
Vertical : 50°
MaterialABS
Total dimensions (W x H x D)30.5 x 16.5 x 10.8cm
Speaker Power (W RMS)NC
Speaker TypeN/A
Impedance (Ω)NC
Loudspeaker diameter (mm)N/A
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
2 reviews
Très bien
Belle qualité de fabrication avec un insert en laiton pour le filetage. Aspect de surface très agréable et bien fini.
Résultat très probant. Utilisé avec une compression Perless pas d'effet de projection.
Je recommande !
This review has been posted for DAYTON AUDIO H6512 Wave Guide High Frequencies 16.5 x 30.5cm
GOOD !
GOOD,I FITTED THEM EMINENCE 2002 S IN2 WAY BOXES.
GREAT HORN !
FAUSTO
This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and...
