ELECAUDIO SC-221OCC Symmetrical modulation cable OCC PTFE Ø7.9mm
4.7 / 5
Reference : 5429
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 07-04-2026.
Based on its expertise in custom-made audio / video cable, ELECAUDIO has designed this modulation cable SC-221OCC without compromise, using the best materials available to meet your expectations and needs.
PC-OCC copper conductors of a large section of 0.71mm² each and the Teflon insulation, which ensures a high mechanical strength, are a guarantee of a pure and detailed reproduction for your HiFi system.
The Double shielding at with 100% overlap ensures protection against interference frequencies: A first shielding made from copper finely woven, then a second made of aluminum strip.
The whole surrounded by a thick PVC sheath protecting the whole.
The construction with cotton filling and paper sheet in order to hold the 2 conductors, allow to obtain a good general flexibility of the cable.
Characteristics :
  • 2 OCC Copper Conductors of section 0.71mm² each, composed of 54 strands of 0.12mm diameter PC-OCC
  • Insulation of drivers in PTFE: high mechanical strength ensures perfect maintenance of tight strands between them
  • Conductor diameter with insulating sheath : 2.30mm
  • Double shielding: Aluminum foil / Braided copper sheath
  • Padding cotton + paper: ensures a good flexibility of the cable while maintaining perfectly the 2 conductors
  • Outer Sheath in PVCof Strong Thickness: Resistant to Shocks and Wear
Specifications:
  • Total cable diameter : 7.9mm
  • Color:Scintillating Red
  • High end finish
Diameter (mm)7.9
Length (m)Sold by length
Number of conductors2
Insulation materialPTFE
ShieldingYes
Section (mm²)0.71
Ground / ShieldingYes
15 reviews
Le magicien !
Pfuuuu, c'est raffiné, spatial, chaud, la musique coule sans stress, la trompette de Clark Terry est dans mon salon comme jamais ...et pourtant monté avec de simples Amphenol. C'est une belle découverte pour moi qui connaissais déjà et appréciais le 3004 et le nemoi 3220. Tout est remis en question...Et merci Audiophonics pour toutes ces pépites que vous proposez. Un audiophile connecté.
This review has been posted for ELECAUDIO SC-221OCC Symmetrical modulation cable OCC PTFE Ø7.9mm
Superbe
Tout respire la qualité dans ce câble. La rigueur de fabrication saute aux yeux et est présente dans chaque détail, comme cette fine couche de téflon qui enrobe délicatement les beaux brins de cuivre d'un éclat chatoyant :) Ou ces fils en vrai coton ( ça se fait rare ). C'est aussi un plaisir de le travailler, joli couple avec les ELECAUDIO RC90-REDC, soyeux et riche aux oreilles, le tout pour un prix dérisoire, il détrône chez moi le NEOTECH NEMOI-3220.
Doux
J'en ai essayé des câbles anglais, français.
Parfois très chers .
Celui ci n'a pas de verdeur dans l'aigu , pas de medium qui crie .
L'écoute est d'un naturel, d'un confort .
Superbe.
 (3)
Decent cable
Decent cable, but due to a bit higher capacity is a bit "warmer" (measured ~100nF/m) but overall sound is nice.
Overall cable build quality is very good.
Compared it with Klotz MC5000 and Sommer Carbokab.
Carbokab works best in my system and can say that ELEC is somewhere between Klotz and Carbokab.
Used Neutrik Profi RCA connectors
Très intéressant
Assemblée de deux façons. Soit brut ou avec gaine isolante cuivre et gaine de finition et prise elecaudio rc 85
Montage avec tresse côté source et 1 fils pt chaud et 1 fils avec tresse
Montage 2 fils pt chaud et tresse des deux côtés et sans hésiter c’est ce montage qui donne la meilleure qualité sonore.
Le top c’est les câbles isolés gaine cuivre
Plus de détails dans tous les registres et surtout une dynamique mieux maîtrisée
Je recommande ce câble sans hésiter
 (3)
