MOGAMI 2933 12-Channel Analog Microphone Cable
10%
The Mogami 2933 is a 12-channel multicore microphone cable specially designed for professional audio applications. This multi-channel microphone cable features high performance and excellent electrical characteristics for stable, reliable signal transmission.
Reduced price!
Reference : 18811
Limited time offer:
17,50 €tax incl.
-10%
15,75 €tax incl.
13,12 € tax excl.
Shipping date: 26-06-2025.
Câble vendu au mètre
MOGAMI 2933 12-Channel Analog Microphone Cable Ø14.3mm
Photo of MOGAMI W2933 microphone cable
The Mogami 2933 is a 12-channel multicore balanced microphone interconnect cable specially designed for professional audio applications. This multi-channel microphone cable features high performance and excellent electrical characteristics for stable, reliable signal transmission. The cable's conductors are insulated with XLPE (cross-linked polyethylene), for optimum resistance to heat and especially to soldering. The structure and manufacturing quality of this cable provide a high level of durability and flexibility for easy handling, even at extreme temperatures down to -20°C (-4°F). Each channel has its own drain wire and a spiral shield of bare copper wire for superior transmission quality to strapping or braided sleeving, while also facilitating installation. Finally, an ingenious system allows you to easily identify the different cables making up the Mogami 2933 :
  • Each conductor sheath is numbered by channel.
  • Outer sheaths are color-coded for quick and easy visual identification.
  • Inner conductors are also color-coded according to the international standard color code for resistors. Each pair is color-coded according to the color combination of sheath and conductor.
Product typeCâble micro
Channels number12
Conductors cross-section0.15mm² (26AWG)
External diameterØ14.3mm
Conductors insulationXLE (Polyéthylène réticulé) Ø1mm
SheathPVC Ø2.8mm
Drain wires0.18mm² #25AWG
Temperature range-20°C / +70°C
Capacitance (@ 1kHz, 20°C)K0 130pF/m
K1 12pF/m
Inductance0.6µH/m
Electrostatic noise2.5mV max.
Electromagnetic noise (@ 10kHz)0.1mV max.
Microphony50mV max. @ 50kΩ/charge
Breakdown voltageDoit résister à 500V/15sec en courant continu
Insulation resistance (@ 125VDC, 20°C)100000MΩ/*m min.
Pair tensile strength (26°C, 65% RH)274N
PackageSold by meter
Diameter (mm)14.3
Number of conductors12
Insulation materialXLPE / XLCPE
ShieldingYes
Section (mm²)0.15
Ground / ShieldingYes
MOGAMI 2933 12-Channel Analog Microphone Cable 0.15mm² Ø14.3mm
The Mogami 2933 is a 12-channel multicore microphone cable specially designed for professional audio applications. This multi-channel microphone...
