NEOTECH NEMOI-1220 Dual Shielded UP-OCC Silver Interconnected Cable Ø10mm
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation cable, combining PTFE insulation and UP-OCC Silver conductors with rectangular cross-section, has a special architecture that significantly reduces the inductance and capacitance effect.
Reference : 13584
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 14-04-2026.
Câble vendu au mètre
NEOTECH NEMOI-1220
Shielded UP-OCC Silver Interconnect Cable Ø10mm
NEOTECH NEMOI-1220 Câble de Modulation Argent UP-OCC Blindé Ø10mm
If you are looking for a very high quality modulation cable with a flawless design, the Neotech NEMOI-1220 is for you. The result is surprising, combining with listening often contradictory qualities such as sitting in the bass and a readable, natural sound scene with high definition in the medium, without auditory fatigue.
Product typeInterconnect cable
Matériau conducteursCross-Section UP-OCC Silver
Number of conductors2
Conductors section0.33mm²
ShieldingCopper-Mylar Foil + Braided Copper
InsulationPTFE + PE + PVC + Cotton
External sheathPE + PVC
Resistance0.054 Ohm/m
Capacity38.19pF/m
Inductance0.86µH/m
External diameter10mm
ColorBlue
QuantitySold per meter
Diameter (mm)10.0
Length (m)Sold by length
Insulation materialPVC
Insulation materialPE
Insulation materialPTFE
ShieldingYes
Section (mm²)0.33
Conductors material (Cable)Silver
Ground / ShieldingYes
20 reviews
Grand câble
J’avais le 3220 qui est un très bon câble entre le DAC et le pré-ampli. Je l’ai remplacé par le 1220 toujours avec des Rca Ramm Audio.
Le grand frère va beaucoup plus loin sur l’ensemble de la bande audio toujours dans la douceur et le naturel. On a l’impression qu’il distille une quantité plus importante d’information, sans tomber dans l’analytique, et vous fait redécouvrir certain titres.
Si l’enregistrement est de qualité et que le reste de votre système est capable d’en tirer la quintessence, on peut frôler le sublime.
Comme Jacques M. (avis du 30/06/2025) je l’ai associé entre le pré-ampli (tube) et l’ampli (classe A) avec le Furutech FA-aS22 qui est aussi un excellent câble très musical même si comme le suggère Didier T. dans son avis du 11/05/2025, il peut parfois engendrer un léger sentiment de frustration dans le bas du spectre.
This review has been posted for NEOTECH NEMOI-1220 Dual Shielded UP-OCC Silver Interconnected Cable Ø10mm
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD connectors from DAC to Pre and WOW. The final piece of the puzzle slotted into place and every superlative applies to how my setup sounds now.
With just a few hours use on it, it's frankly revelatory.
N'hésitez pas
J'ai associé ce câble à des connecteurs xlr de la même marque modèle Nex-occ. Il y a eu des gains à tous les plans : matière, profondeur, douceur, détail. C'est un excellent câble qui dépasse en qualité les câbles tout faits (de bonne facture certes mais qui valent plusieurs milliers d'euros).
l argent a fait mon bonheur
Fantastique cable .précis détaillé pas tres loin d être analytique tempéré dans mon système haut rendement par le furutech violet qui prend le signal en charge a la sortie du monoceros. Il fait donc la liaison entre le holo spring 3 et le monoceros.
L alliance entre l argent du neotech et le cuivre du furutech me plaît bien.Monté sur xlr EIZZ
excellent silver cable
The cable is a big surprise for me. I was planning to replace the legendary Siltech SQ-110 Classic MK2, which I have been listening to for 20 years. The list price of the SQ-110 1m pair was 2600EUR. This NEMOI-1220 with DIY assembly at 1/6 of the price slightly surpasses the SQ-110 cable in sound already before burn-in.
A terrible negative is the peeling of the 0.1mm thick clear Teflon insulation covering the square silver conductor.
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation...
