NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables.
The Neotech NEMOI 3220 modulation cable, combining PTFE insulation and OCC pure copper conductors with a rectangular section, has a special architecture allowing a strong reduction in the effect of inductance and capacitance.
If you are looking for a high resolution cable, the Neotech NEMOI 3220 can meet this expectation.
4.8 / 5
Reference : 11422
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 07-04-2026.
1MII B08+ Class D Amplifier Bluetooth 5.0 Receiver AAC SBCI QCC3034 2x50W / 4 Ohm
NEOTECH NEMOI-3220
BALANCED INTERCONNECT BRAIDED CABLE OCC PTFE Ø10MM
The result is surprising, combining listening qualities that are often contradictory, such as a seat in the bass and a readable, natural sound stage with High Definition in the midrange without auditory fatigue.
The shield can also be used as a conductor.
- Cable structure OCC Neotech NEMOI 3220 -
NEMOI-3320 Structure OCC Neotech
Technical characteristics :
  • 2 OCC copper conductors with rectangular section + 1 copper shielding sheath
  • 3-layer insulation : PTFE and Polyethylene in second layer, PVC outer sheath
  • Cable outer diameter: 10mm
  • Sold by meter
Diameter (mm)10.0
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
19 reviews
Mysterious foil shield
The transparent plastic on the rectangular conductors is not so difficult to remove, when you scrap it open with a knife on the “short” side of the rectangular. It then opens up and you can pull it off. Be carefull not to cut through the copper foil when stripping the cable.
Much more difficult is the incorporation of the foil shield to ground. To my logical sense it has to be connected to the braided shield on both sides, it has to be grounded otherwise it isn’t doing anything besides trying to become a capacitor, but I cannot find that confirmed anywhere. So only 3 stars because of this. The foil is isolated from the braided copper in this cable, which is quite unusual. The foil easily breaks and then you have to start stripping the cable again.
Since I go from unbalanced to balanced signal, I put a small resistor of 100 Ohms in parallel with a tiny capacitor of 100 nF in a special XLR plug (the Neutrik doesn’t allow 10 mm wire) on the receiving balanced end, between the braid+foil and ground (pin 1). On the unbalanced side the blue wire will be connected directly to the braided copper and the foil copper.
This review has been posted for NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm
THE best cable ever
Better than Topping TCX1 with 6N wire in which there is a cable from the Taiwanese company Serost M-3 under the armor.
This cable is wonderful.
Cable fabuleux.
Permet d'accéder à des détails et de la finesse en profondeur. Médium à la fois étoffé et différencié. Mérite les meilleurs connecteurs. Enterre les bricoles bruyants à base de Duelund, Belden etc... Surpasse un Xsangsane argent 9001 grâce à davantage de structure et de matière tout en restant très fin.
Système déjà bien abouti à base de triodes et enceintes 94db.
En un mot... Majestueux !
Voici donc un avis qui emboîte le pas à celui que j'ai modestement rédigé concernant le Furutech FA-aS22.
Et pour peu que l'on évacue tout préjugé tarifaire, la divine surprise est à portée de main...
Ainsi, les Nemoi 3220 (tjrs soudés à la Mundorf Supreme sur des Switchcraft dont il a fallu réaléser à 10,5 mm les orifices des bouchons en alu) ont donc remplacés les FA-aS22 (ayant eux-mêmes plus de 50 heures au garrot) entre mes Nuprime DAC 9SE et STA 9X.
Si les vraiment "très bons premiers" m'avaient laissé sur un je ne sais quoi de frustration par un manque d'ampleur, je les ai donc troqués pour ces Nemoi 3220, juste "pour voir" (ou plutôt entendre) : à ce tarif-là, il est des tests qui ne se refusent pas...
...et alors là...
...je ne m'attendais absolument pas à cette musique-là !
Une matière retrouvée, des basses électriques, contrebasses et violes de gambe sensiblement plus étoffées dans leurs premières octaves avec une complexité harmonique sensiblement plus riche...
...des voix plus palpables matures et charnelles...
...des instruments à vent et à cordes (acoustiques et électriques) plus concrets...
Comme si, en fin de compte, ce gain en fréquences inférieures redonnait aux instruments cette fameuse complexité harmonique nous rapprochant de la vérité.
Le tout avec (et par compensation), il est vrai, un sentiment de léger recul du niveau des cymbales, mais, dans mon cas, en totale conformité avec la configuration mise en œuvre.
Bref, ce Nemoi 3220 contribue à une musique délicatement détaillée, envoûtante et "matérielle"...
Tout prend une place naturellement "en ordre", sans sentiment que telle partie du spectre bouscule ou phagocyte telle autre, me laissant à penser que les Nemoi 3220 sont un peu moins "audiophiles" et un peu plus "mélomanes" que les excellents FA-aS22.
Tout comme pour le Ludic Silenos, sans trop savoir pourquoi (et sans chercher à le comprendre non plus), ce sera sans doute le dernier.
Deux détails pour conclure :
- concernant son montage, bien veiller à considérer que les conducteurs sont constitués de monobrins en nappe doublement isolés : une fois dénudées les gaines rouges et bleues, reste sur chacun un isolant transparent à éliminer délicatement pour assurer un soudage digne de ce nom.
- ne surtout pas le juger "from scratch", car dans ce cas, il peut verser dans un chouïa de vulgarité, ce qui disparaît intégralement une fois franchies les 20 heures...
Ce câble est bien dynamique, beau grave et bas médium.
Il met juste légèrement les aigus en arrière .
Il me fait pensé au câble secteur Furutech T 31 ( vert ) pour ses timbres .
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The Neotech  NEMOI 3220...
