The SC-Kolorith 1 from Sommercable is a hybrid cable designed to transmit both audio data and power in a single line, making it an ideal solution for demanding installations in studios, architectural lighting, home automation, or smart sound systems. Thanks to its shielded twisted pair (110Ω impedance) and 2mm² power conductors, it ensures reliable signal transmission and stable power supply up to 50V, even over long distances (up to 1000m). Its compact, flexible, and UV-resistant design makes it a suitable choice for both indoor and outdoor applications.
This cable is particularly recommended for connecting Meyer Sound low-voltage/smart products, lighting systems, or building management installations. Its AL/PT foil shielding and OFC copper conductors ensure excellent protection against interference, high electrical conductivity, and increased durability, even in complex environments.
The SC-Kolorith 1 stands out for its ability to combine balanced audio signals and power supply in a single cable, simplifying installations and reducing clutter. The twisted pair for data, with an impedance of 110Ω, is specially designed for high-quality audio transmission, while the two 2mm² power conductors can carry voltages up to 50V with minimal losses. This versatility makes it a hybrid cable suitable for professional applications where reliability and performance are essential.
With an outer diameter of 7.40mm and a UV-resistant PVC jacket, the SC-Kolorith 1 is both lightweight (87g/m) and durable, capable of withstanding temperatures ranging from -25°C to 70°C. Its internal structure, composed of 48 strands of 0.10mm tinned copper for the audio section, ensures excellent flexibility and a long service life, even after numerous bending cycles. The 100% shielding provides effective protection against electromagnetic interference, ensuring stable signal transmission.
| Specifications | |
| Product type | Hybrid power and data cable |
| Conductors material | OFC copper |
| Conductors number | Audio: 2 Power: 2 |
| Conductors section | Audio: 2x 0.38mm² (21AWG) Power: 2x 2.0mm² (14AWG) |
| Outer diameter | Ø7.4mm |
| Signal transmission | Symmetrical |
| Outer sheath material | PVC |
| Number of channels | Audio: 1 Power: 1 |
| Shielding | AL/PT foil |
| Shielding factor | 100% |
| Conductors insulation | PP |
| UV resistance | Oui |
| Temperature range | -25°C / +70°C |
| Impedance | 110Ω |
| General | |
| Length | Sold by the meter |
| Diameter (mm) | 7.4 |
| Number of conductors | 4 |
| Insulation material | Polypropylene (PP) |
| Shielding | Yes |
| Section (mm²) | 2.00 |
| Section (mm²) | 0.38 |
| Conductors Plating (Cable) | None |
| Ground / Shielding | Yes |
